Pipo M9 Pro RileyROM 3.0
Originally posted by Edius View Post
Originally posted by Starcopy View PostI'm sorry to say that it's here a complete disaster. Battery drains faster than I can look. It drops 2% in about 5 minutes. The red line is for 3G, only problem is: I don't have a 3G model. Gps say it's on, but that is also off. I have the libril-rk29-dataonly file in it. Did all the things you said. Has enyone a suggestion?
I'll show you four screenshots with battery usage: two in original state and two edited in Paint (with drain caused by some games and browsing removed).
I have ~10% battery drain in 24 hours (if we exclude approx. 4 hour of intense usage to see if i encounter some black screens, reboot, etc), but in a real standby time battery drain will be much lower.
I have no idea what could cause this huge drain but a real solution will be to reflash RR3.0 pointing to kernel "kernel_M9Pro3_407_cpu1608_gpu600_ddr720" in ROM Flash Tool.
Originally posted by teretzis View PostHello to all, flashed new ROM today, kernel is the same only difference is the battery doesn't consume as much, still testing to see what new tweaks it has to offer will inform. Thanks
" Anna Ye If you mean the firmware for M9 pro. it is the same one as the official firmware 20140504 version, just upload it to another link."
Originally posted by rrileypm View PostIf anyone has a chance to download and flash this firmware, I'm curious if this is the one with kernel 407 in it...or if it's an even newer kernel.
Originally posted by devin View PostHi all For me I come back since 3 days to the 2.72 ROM ( gps on/off ok... ) but with the 407 kernel and all is ok. this night only 1% battery drain for 10h with the wifi off. No lag no hangs, no reboot
Originally posted by devin View PostI have 2 pipo M9pro WIFI and I teste the "kernel_M9Pro3_407_cpu1608_gpu600_ddr720" on the 2 pipo
for the moment it's y best configuration and the 2.72 ROM is for me the more stable.
With all other kernel with overclock the 2 pipo don't boot...
I've just posted a new ROM for the M7 Pro from firmware dated 3/26/14.
Here's the link:
I would like someone to try this ROM using kernel #407 and see if it is an improvement over what's missing in this ROM.
Depending on how it works, I can port this M7 Pro ROM over to the M9 Pro...by porting, I mean simply changing the boot animation and model ID to M9 Pro.Randy
No time...
Originally posted by rrileypm View PostI've just posted a new ROM for the M7 Pro from firmware dated 3/26/14.
Here's the link:
Depending on how it works, I can port this M7 Pro ROM over to the M9 Pro...by porting, I mean simply changing the boot animation and model ID to M9 Pro.M8pro
M9pro (current tab)
Originally posted by cshock2010 View PostM9Pro Modified Kernels
for RileyRom 3.0
Kernel #407
Kernels407_M9Pro_RR3_1608.zip
Kernels407_M9Pro_RR3_1704.zip
Kernel #406
Kernels406_M9Pro_RR3_1608.zip
Kernels406_M9Pro_RR3_1704.zipProud M7Pro owner and Freaktab fan
There are currently 1900 users online. 0 members and 1900 guests.
