Please can you post a link to your kernel #404, and what modification ? speed or battery drain ?
Pipo M9 Pro RileyROM 3.0
Originally posted by fhkhattak View PostHi riley,
Im new to the forum but have been using your awsome roms since beginning.
I clean flashed version 3.0 - found that once i turned off location, it became grey and could not be turned on again
I clean flashed 3.1 then - this time i can change the location setting (device only, high accuracy etc) but there is no button to turn the location off completely
I was wondering if its only me or anyone else has the same problem?
thnx!
Originally posted by stevejc View PostI have Also this bug with m8hd I have resolved it by using the app power toggles
no exchange services
Hello Randy,
thanks for your continuous job making new rom for our tablets. I wanted to try out this new version, unfortunately the Exchange service isn't part of it. I tried to save the apk with Titanium backup in the 2.7.2 and restore it in the 3.0, but it keeps crashing all the time. I tried almost all the possibilities, even taking the email app from the 2.7.2, but i wasn't able to make it.
I came back in 2.7.2, i can't work properly with my pro email accounts without this service.
Originally posted by Kenneth View Posti am looking into change my m9pro battery 7800mah to that of the M8HD 8000mah to gain more battery life
i just need to find one on aliexpress.com
Originally posted by colinabroad View PostWhy not just buy 4 replacement phone batteries and link them together?? saves you M8HD for the sake of a 2.5% increase in potential capacity!! or is your M8HD dead?PROUD owner of PiPO M9 Pro
PiPO P9 best tablet ever owned!!!
PiPO Tablet Freak and Flashaholic!
No good if it doesn't fit.
Also be VERY careful when opening your tablet. When opening my wife's Max M9, I damaged the spring clip in the microSD card holder. Waiting for a replacement battery for her tablet. Found the best price was from BangGood.
thnx!
There are currently 1836 users online. 0 members and 1836 guests.
