Pipo M9 Pro RileyROM 3.0
Originally posted by blusydays View PostWhat is modified in those kernels ?
kernel_M9Pro3_406_cpu1608_gpu600_ddr720.img
kernel_M9Pro3_406_cpu1704-high_gpu600_ddr720.img
kernel_M9Pro3_406_cpu1704-low_gpu600_ddr720.img
kernel_M9Pro3_406_cpu1704-standard_gpu600_ddr720.img
kernel_M9Pro3_407_cpu1608_gpu600_ddr720.img
kernel_M9Pro3_407_cpu1704-high_gpu600_ddr720.img
kernel_M9Pro3_407_cpu1704-low_gpu600_ddr720.img
kernel_M9Pro3_407_cpu1704-standard_gpu600_ddr720.img
these are overclocked kernels
hmmmm...
Originally posted by robinjoo1 View Postnope 406 is horrible for me lagggg..
Sent from my M9pro using Tapatalk
-Power drain is at best minimum at normal use, except for gaming.
-wifi is stable
-smoothens the UI performance
-almost lag free
-overall performance is the best experience of all the kernels I've used
Somehow, the "unfortunately" problems annoyance occurred when I sync off, tablet went laggy too. I think its a fw problem.
BTW, anybody here knows how to uninstall/remove TGB engine performance which I installed thru CWM?M8pro
M9pro (current tab)
Originally posted by Kenneth View Posti have an m9pro not a m8hd
Problem getting into Reboot to Flash Mode
This will be the 4th. rom I'm putting on my M9 Pro, the last was 2.71 Kit Kat. Previously after hitting Esc + Reset the tablet would intoan animated Android figure for flashing. No all it does is go into the TRWP boot utility. Am I supposed to flash from that utility? I'm not really familiar with TRWP at all. I've been trying to Flash 3.0 and I can't get Windows to to even find my tablet. My Win7 tablet is the only machine I have ever had luck flashing the tablet with, my Desktops never recognized my tablet, but now my laptop is unable to work using either Reboot to Flash Tools.
I had to order a new Usb to Micro cable, misplaced my Pipo cable. This new cable seems fine though.
I tried both Host/Usb and just the Usb slot on the tablet, nothing seems to get the Found Rockchip Device banner.
Thanks,
Phil
Has anyone noticed if the downloads app bug exists on the stock version? Its worth knowing to rule out any of my changes.Randy
There are currently 2181 users online. 0 members and 2181 guests.
