Pipo M9 Pro RileyROM 3.0
Originally posted by colinabroad View PostI just uploaded mine to drop box, was about to give you the link when I realised I am currently running Pipo stock aarrgghh - do you want it anyway? or do you want to wait for someone else to wake up?
But don't see the link????People who think they know everything are a great annoyance to those of us who do.
bootanimation on dropbox
https://www.dropbox.com/s/27159vwyd1...tanimation.zip here ya go. One stock Pipo boot animation for you to play with. Let us know how you get on. Cheers, colin.
Updated modified kernels
M9Pro Modified Kernels
for RileyRom 3.0 [KK]
Kernel #407 kernel_M9Pro3_407....zip
Kernel #406 kernel_M9Pro3_406....zip
Kernel #386 kernel_M9Pro3_386....zip
- Individually zipped
- Adjusted voltages in standard kernels
use 7zip or winzip to extract.Proud M7Pro owner and Freaktab fan
Originally posted by belier View Post
My Hay Day farm on my computer monitor.
Connected using Pipo X5 dongle.
I haven't tested it thoroughly, but it seems to work better than with JB ROM's.
Kernel #407 - kernel_M9Pro3_407....zip
Kernel #406 - kernel_M9Pro3_406....zip
Is there any OC on these Kernels? I have the 407 , with Ram 720 OC. What are the differences?
If what you're using right now is working fine, no need to switch to another kernel.
Thanks for the appreciation.Proud M7Pro owner and Freaktab fan
Thanks Man
Originally posted by colinabroad View Posthttps://www.dropbox.com/s/27159vwyd1...tanimation.zip here ya go. One stock Pipo boot animation for you to play with. Let us know how you get on. Cheers, colin.
But I don't think this was baked with a twist on the boot and I am missing something/ some file or whatever. It is no big deal to have a few seconds of darkness. So rarely do I give, but I give. I will wait to a possible 3.1 if one comes. I still appreciate all the work that RR does for us. Big Time...People who think they know everything are a great annoyance to those of us who do.
RR 407 Kernel - other kernels
ThanksPeople who think they know everything are a great annoyance to those of us who do.
Originally posted by PipoM9Pro View PostMy , my 407 RR kernel occasionally just boots. The 406, I had some hangs. So I am wondering if the Gggggas kernels would work. Are the voltage tweaks all that done, are they lower? Or what are the major changes it these kernels? Just don't what to damage the hardware, especially around voltage changes.
The newly uploaded ones have some voltage tweaks(you still have all the standard/low/high options) but I am unable of extracting the zip files. I was going to install RR 3.0 and the new 407 now so I hope that CSHOCK2010 uploads them again.
Question kenneth - can you tell if the performance is better or smoother
Originally posted by Kenneth View Postkernel used on the official pipo download site (PiPO M9pro_update_andriod4.4_20140504.img) is #406 as i flashed kernel.img right now so i don`t know where #407 came from
dear randy...can we have swap file support on the m9pro kernel?
I use ram manager pro and it says that swap file support is unavailable...swapping to external sd is cool plus having more than 2GB of ram is better tooPeople who think they know everything are a great annoyance to those of us who do.
Originally posted by Gggggas View PostYeah I had some reboots on 407 too but they are rare. Using 2.7.2 kernel 407 standard 1608 with 720.
Use 7zip or WinZip to extract.Proud M7Pro owner and Freaktab fan
My Try on the OC Kernels
Fail - booted about 3 times - vertical lines all across the screen- never boot into the OS.
Next on the list:
kernel_M9Pro3_407_cpu1608-standard_gpu600_ddr720
Worked, booted 2 times - but is up and running - Bench Marks are a bit lower (seems smooth thou) with the kernel the 407 RR kernel, but who knows it may be a little more stable on my pipo m9 pro...thanks guysPeople who think they know everything are a great annoyance to those of us who do.
I've updated this ROM to v3.0.1.
I've fixed the bug which prevented the ability to connect to an Exchange email account. I've also included kernel 407 in the kit as an optional kernel to flash. The default is still kernel 406.
Just use the download link in post #1Randy
There are currently 2313 users online. 1 members and 2312 guests.
