Pipo M9 Pro RileyROM 3.0
    What I just told you about what I'm doing in the previous post concerning the Omni ROM is plan "B". I'm still hoping for one of you guys to come through with plan "A", which is a ROM dump...really of the whole installation would be great.
    I'm going to need:
    parameter
    system.img
    boot.img
    kernel.img
    recovery.img
    But if system.img is all you can get...I can live with that. My plan is to incorporate these new files into the 3.0 ROM kit, since all this is is an update...the other parts are still being used from my ROM, or the stock ROM.
    This is all of Omni's work, and I don't propose to change anything...except to put it into a package that is flashable with a PC.
    Randy
      Originally posted by robinjoo1 View Post
      hey i tried to extract the .zip file of the firmware but it failed both with peazip( unsupported method)
      and 7-zip ( unsupported compression method )
      am i doing something wrong?
      i also tried it on my tablet and that worked fine why?
      The zip file is signed as a firmware update. I'm just speculating here, but I think that a zip file that is signed, can't be extracted with those apps. On a PC, it shows up as a regular zip file.
      My experience is that if you just change something in the zip file and save it, usually it doesn't work, because it isn't signed anymore. Results may vary, though.
      Randy
        in the opening post the one that also includes your flash tool that where im referring to
        and pdf with instructions
          If you look at the folders of the ROM kit, there is a sub folder with a different tool...and it has instructions in a txt file written by Finless.
          Randy
            problems in the 3.0.1 zip file
            I've just been looking at the RR 3.0.1 zip file and see something that might explain some of the trouble people have been reporting.
            First off, downloaded Pipo_M9_Pro_RileyROM_3.0.1.zip from the first post in this thread.
            MD5 sum: 5f74607dc76be131f4f998076705e662
            I first tested with the linux "unzip -t" (derived from Info-ZIP), each of the files came back with this error, for example:
            Code:
            file #184 (RileyROM/system.img):
                     mismatch between local and central GPF bit 11 ("UTF-8"),
                     continuing with central flag (IsUTF8 = 1)
              inflating: RileyROM/system.img
            but otherwise unzip'ed ok. I ran it through 7zip's test function, it also came back with 192 errors about "Unsupported Method" (one for each file).
            Unzipping with linux's 'unzip' (Info-ZIP) creates 194 files using 821MB.
            Unzipping with 7zip on linux also creates 194 files, but this time using only 11MB, many of the files are 0 bytes, RileyROM/kernel407.img (11MB) is the only file which contains anything.
            I don't know why there is a discrepancy between 192 and 194 files.
            The only other RileyRom.zip I have near me right now is the old 2.0 version, it does not report any errors in the zip file using either of the tools.
            Is there an official link to the original 3.0.0 zip file existing still? (not looking for a google drive upload, just the original freak-tab.de one, thanks)
            Workaround: for the 3.0.1 zip download, don't use 7-zip.
              I use either Linux or WinRAR 64bit to zip...depending on if I need to work with the files in Windows or not. I just upgraded to the newest version of WINRAR.
              Randy
                zip
                I suspect the trouble arose from repacking the zip with the 407 kernel using a different computer or different program than the original 3.0.0 used. Either the locale or the UTF8 awareness of the zip program was different. It seems to be the encoding used in the filenames so perhaps the files pulled from a different filesystem type?
                  That's very possible. The original zip was created in Linux and I edited it in Windows with WinRAR. I've been doing it that way since the beginning...and never heard any complaints.
                  Randy
                    Kenneth...I never can please you, can I? Hate is a pretty strong word, considering I spent almost as much time and effort in this cool boot animation as I did the whole ROM. Of coarse, I'm no artist, like Tattman65...but the 3D look is much more pleasing on the eye than that tired old Pipo logo.
                    Just giving you a hard time, man...to each his own.....I just hope the ROM is an improvement over the 29 previous ones.
                    Yes Riley,who's looking at the bootscreen ,it's 1 minute on the screen.
                    there are hard headed people ,i am totally not interested in the bootscreen.
                    Can you make one for Kenneth,so he can watch it all te time?
                      I have a new firmware update for the M7 Pro. I'm working on v3.3 for the M9 Pro with this firmware.
                      My question is, which kernel should I include in the kit?
                      Is 406 or 407 best? Or should I include both?
                      Randy
                        The 407 with 720 ram is by far the best as others have stated. I use my tablet pretty heavy and have had RR3.0 installed since you posted and have only had 1 force restart while backing up via titanium.
                          OK, I will include 407 (stock) as the default kernel...and add the custom kernels from 407 in the kit, as well.
                          Edit: I've decided to leave the custom kernels out of the ROM...there's too many to choose from. You can still grab from here: https://www.mediafire.com/folder/68bi4uj49si9w/3.0_407
                          Randy
                            Will 3.3 be 4.4.4? Or still on 4.4.2?
                              This one is 4.4.2.
                              I have played around with that 4.4.4 ROM posted above, but couldn't get it to work. It's some other developer's headache...not mine...hahahaha!!!!!!!
                              Randy
                                v3.3 is available!!!!!!
                                Here's the new thread for RileyROM v3.3:
                                Randy
