I installed the 4.4.4 rom. It does have some nice features I like; the privacy settings, better menu's, ... While working with it, had no reboots, ...
The only thing that seemed to be incomplete is the widget system. The widget menu does not have all the widget we're used to (calendar, gmail, ...) Probably this is due to half of the google apps not being thre in the beginning.
I tried to flash those, with luck, but still couldn't get the widgets to work.
Anyway, that's a short recap. I was looking into dumping the rom for you.
No luck so far, i can't seem the device to recognized to switch it to programming mode.
What are the thing I should be looking for?
- set usb debugging mode on
- deactivate all other modes (mount as external storage, ...)
I'm using RKtool 2.1 and also tried manually to connect through adb.
Is there a key combination I should know of? How do I boot into "fastboot"?
EDIT:
ok, allready found this:
But what I'm really looking for: I remember being able to boot into a "fasstboot" menu on my phone.
Anywone know of other things to try or where to look?
Edit2:
ok, i have "android composite adb interface" listed in device manager.
Tried to match pid and vid in rktool to recognise the tablet
MSC_VID=0x2207
MSC_PID=0x0011
Rktool now sees the device, but no luck into making it switch to programming mode.
edit3:
got adb access over network
