Pipo M9 Pro RileyROM 3.0
reeboots ?
This sounds like a good plan given what Pipo have not done! OK - I switched to 3.0.1 four days ago having stopped several months ago at 3.0 whereafter I had been using Pipo's last Release which was unusable given the number of forced stops and auto reboots.
3.0.1 seems far more stable BUT I did get a random shutdown yesterday in the middle of reading a book on Kindle it required a stab in the reset hole and a reboot to get it going again. Battery seems to be holding up OK and GPS worked for the first time for a long time. I will take note of all 'funny stuff' and come back in a week with a report. Hopefully if others can do the same Randy will have some decent info to work with. Mine is an M9Pro3G with no3G card. Running 3.0.1 Parameter4 and #407 kernel. Let's hope Randy can breath one last breath of life into this popular tablet.
Nothing really happens in the system partition that would cause a lag...it's designed to be read only in the non-rooted world. Technically, you could have a completely full system partition and it wouldn't affect performance. All of the cache is being done in the cache partition and sometimes stuff happens in the data and userdata partitions. If you are experiencing a lag, over time...you might want to wipe the cache partition from TWRP.Randy
Originally posted by rrileypm View PostNothing really happens in the system partition that would cause a lag...it's designed to be read only in the non-rooted world. Technically, you could have a completely full system partition and it wouldn't affect performance. All of the cache is being done in the cache partition and sometimes stuff happens in the data and userdata partitions. If you are experiencing a lag, over time...you might want to wipe the cache partition from TWRP.
PROUD owner of PiPO M9 Pro
PiPO P9 best tablet ever owned!!!
PiPO Tablet Freak and Flashaholic!
Originally posted by blusydays View Post@Kenneth,
Great wallpaper, can you tell me where you found it please.
my upload 4 wallpapers i use...http://www.mediafire.com/download/vp...WallPapers.rarPROUD owner of PiPO M9 Pro
Originally posted by Kenneth View Postyes i think it`s a known issue with this rom
You need modified version of DocumentsUi.apk and MediaUploader.apk
I have made a zip , copy these files to /system/app with rw-r--r-- permissions.
You need a R/W system, done for example with ES ExplorerAttached Files
There are currently 2187 users online. 1 members and 2186 guests.
