Pipo M9 Pro RileyROM 3.0
    I just used the kernel that was in this firmware. If there is a newer one...I don't have it. Arctablet must have an inside contact we don't have. It makes me wonder if there is yet another firmware floating around.
    And, no....I don't read the threads on Arctablet, or even try to pay attention to what he's doing.
    Randy
      That's interesting:
      cracktech said
      I SEE A MAJOR PROBLEM ON THIS UPDATE – (update to version #407 problems) My SYGIC Navigation refuses to run
      My Microsoft OneDrive doesnt run
      My local TV on demand app doesnt run on this #407 KitaKat version it was OK on the #404 version.
      I am going to back to #404 version anyway theres NOT much difference in this version.
      So maybe Pipo decided to release #406 because it's the most stable version. #407 seems kinda beta-ish to me.
        plz help
        hey i have set
        ro.rk.systembar.tabletUI
        to true but it doesnt work if you know what i meand
        i doenst make button on bottom
          Originally posted by robinjoo1 View Post
          plz help
          hey i have set
          Doesn't work in KK.
            how to make it work is there any way to it?
              No, it's a trick that worked only in JB 4.2.
                ah wel i will still start digging
                btw starcopy are you the same as this one
                btw plz make an option to display battery % at top right i can find an option
                  I just have downloaded image from Pipo and extracted kernell with ROM_Dumper_Tool provided in RR 3.0
                  Result is here Click image for larger version
ID:	433720 and look's like a different one to me.
                  I'll update with this kernel just to see what is different.
                  I read threads there only when I can not sleep
                  L.E
                  Ok, flashed kernel extracted from Pipo image.
                  It's the same, differences in checksums exist...in essence it's the same #406 kernel without the fireman hat
                  Looks like we have the correct one.
                  Ahh, and another bug corrected is with missing cursor...is back to us.
                  Tnx again.
                    And camera bug when used from other program is that corekted to?
                      camera workt fine here usings stock one tho
                        Yup, the same.
                        For battery there is an option to put it on the left top site. You can use the app battery hd for it.
                          Yup, the same.
                          never mind see magic of reboot
                            Stock launcher
                            stock launcher cant display in portrait mode.
                            and anyone who can help me how to root a stock kitkat rom? my TPSparkyRoot tool dont work on kitkat.
                              The Rileyrom is already rooted.
                                i know but i want a rooted stock rom... not a custom rom... so any suggestions how to root kitkat?
