Pipo M9 Pro RileyROM 3.0
kernel used on the official pipo download site (PiPO M9pro_update_andriod4.4_20140504.img) is #406 as i flashed kernel.img right now so i don`t know where #407 came from
dear randy...can we have swap file support on the m9pro kernel?
I use ram manager pro and it says that swap file support is unavailable...swapping to external sd is cool plus having more than 2GB of ram is better tooPROUD owner of PiPO M9 Pro
PiPO P9 best tablet ever owned!!!
PiPO Tablet Freak and Flashaholic!
Rooting M9pro kitkat 4.4.2
Originally posted by eekram08 View Posti know but i want a rooted stock rom... not a custom rom... so any suggestions how to root kitkat?
Good enuf
It's not JB smooth but its fine to use now, after all the updates done, its good to go, not dying instantly anymore. Gonna abuse this one tonight. Maybe try out our oc kernel by sir Jay Navea from our FB group Pipo PH.
Thanks Randy, we appreciate it alotta!!!M8pro
M9pro (current tab)
Originally posted by Kenneth View Postkernel used on the official pipo download site (PiPO M9pro_update_andriod4.4_20140504.img) is #406 as i flashed kernel.img right now so i don`t know where #407 came from
As I wrote in post # 23 ( before Randy release RR3.1), downloaded image from Pipo (PiPO M9pro_update_andriod4.4_20140504) extracted and flashed resulting kernel...is #406, Randy has included this version in RR 3.0.
I just sent an hour ago an email to Anna Ye with this problem, maybe she will clarify this for us.
First of all, thank you Randy for all your hard work.
Unfortunately, this ROM is a no-go for me. 5 restarts in 7 minutes is not really what I was looking for
Every time after 30sec - 1 minute of use it would hard restart itself (even with factory reset). Clicked settings -> restart, clicked on gallery -> restart, [...] the last time it shut down for good while trying to connect to wifi.
Going back to RR2.6 where everything was great, just the unlock button was fiddly
Cheers.
Originally posted by Jak View PostRestarts are temporary. after all the google updates finishes, the restarts stops. Using the 3.1 with 407 kernel is quite smooth. Now using the oc kernel from RR 2.5.2 to make everything smooth, at the cost of the battery. darn!
I am just adding titaniumso I can restore folowing a nightmare. Would not erase NanD,ot Pipo rom loaded, then started loading RR3.0 and it stopped 25K in - thought I had bricked it but the old trick with a toothpick and various combations of power/esc got meback up & running. Will report in when all is OK - need to get vpn runnngout of china to download titanuim !
update
Originally posted by madsega View PostProblem is that I can't get to the step of updating anything. Power, Google Play, Use existing email, insert email, when to insert password -> shutdownM8pro
M9pro (current tab)
There are currently 2677 users online. 1 members and 2676 guests.
