Arnova 10b G3 with EXT4 and CWM - BETA 2 ROM
    I send you a pm again try that please you need your pc for that.
    Let me now please.
    Because it wonderfull the modded one
    Verstuurd van mijn Freaktab met Tapatalk
    if you love my work please buy a coffee
    <form action="https://www.paypal.com/cgi-bin/webscr" method="post">https://www.paypalobjects.com/en_GB/i/scr/pixel.gif
    </form>
      If your copying it from SDcard, remember to set the permissions on the files once they are copied to /system/framework. If you dont do that, it probably will hang on boot.
      Snakekiller, you should make a CWM .zip update and let them use CWM. Much easier
      You should me how to do it so your the master there
        Ok ill try too make a cwm
        </form>
          I didn't even think about the permissions...I'll try that, now.
          Randy
            ok ill now what you do wrong.
            the downloaded file is zipped.
            first unzip it than you have the framework-res.apk file
            </form>
              Ok here is the cwm zip file.
              Sorry try that please , ill now sorry again.
              Just choose install zip in cwm.
              And hope its ok now.
              </form>
                I finally got this to work by changing the permissions on the new file after I copied it to the Framework folder. This was like playing a video game, because I had to space my actions between the error screens. I would suggest, if anyone else installs this to use that CWM version.
                After reboot, I had to re-enter my GP account information, for some reason. But everything works nicely.
                Randy
                Randy
                  Yes thats normal i had it too
                  </form>
                    Anybody who has not installed this modded framework manually please try this first
                    And let me now if it replace the original .
                    Thx in advance
                    </form>
                      I tried the cwm zip version of the mod, and it worked well... Much easier!!!
                      Randy
                      Randy
                        Have you tried on a system without the modded framework ?
                        Sow yes , ok im happy its work great
                        Thats what i will do in the future for easy rom updates too .
                        Sow you don't need a pc anymore for flashing.
                        Just your tablet and cwm recovery.
                        </form>
                          Sorry I've not tested this before - we got a new puppy yesterday so been a little occupied!
                          Just installed and working fine - the new transitions are nice. I copied in manually and set the permissions, all looks good so far, though I had to re-enter my GP credentials just like Randy.
                          Andy
                            Thats normal your fb account must be entered again too
                            </form>
                              SK - question...every time I install your new build.prop & do as needed (i.e. wipe cache & dalvik) upon restart i'm stuck on the resistive calib screen - which I can't get past having a capacitive. This means I have to restore using CWM. I can't effectively test it due to this.
                              Any decent way of getting past this, or is it a case of waiting for the final release with the updated build.prop included?
                                have you try it only with cache, and not with dalvik cache
                                if you use dalvik cache you have this problem.
                                </form>
