Arnova 10b G3 with EXT4 and CWM - BETA 2 ROM
    testing now....
      What's your speed now
      Verstuurd van mijn Freaktab met Tapatalk
      if you love my work please buy a coffee
      <form action="https://www.paypal.com/cgi-bin/webscr" method="post">https://www.paypalobjects.com/en_GB/i/scr/pixel.gif
      </form>
        Is there something you can do about the DT calibration screen?
        My tablet froze and I had to reset it.. When I rebooted, I ended up at the DT calibration screen, is there anyway you can avoid this?
        Lode
          Yes recover your backup with cwm
          And change the name of the apk in system/app
          And make a new backup
          I hope bob remove it in the final version
          </form>
            What if I just delete the Wizard.apk?
            Will it damage my system?
              First make a backup with other name
              Then remove it and restart and look if you have no errors
              </form>
                Just deleted it...
                Not getting any errors (yet)
                Thanks for the help!
                  Just got home, sorry. Ok signal appears faster- just did a few tests and getting around 1mb both dl and ul. I'm guessing I just have a rubbish signal with the new wifi router virgin just gave me, just surprised that the range on the 10b is worse that I had on my old 7g2. I could pick up a signal most places round the house woth that, can't with this. Plus youtube, iplayer etc still jumpy and buffering left right and centre. Don't know what we can do about that tho...
                  Will stick with this build.prop for now. Would be good to get init.d as well.
                  But do you think adding further echo lines would help? Took a look at some wifi tweaks which focused on this.
                  Sent from my Freaktab using Tapatalk 2
                    You can try
                    If you look at my tests its great.
                    And youtube plays without lags for me
                    I use wpa2 channel 11
                    If you use wep it is slower than wpa2
                    Or it is your router
                    </form>
                      I can see that's which is why I'm puzzled. Will look at it some more
                      Cheers sk, am jealous :banghead:
                        Bob please remove the tscallibration.!!!!!
                        I renamed all 3 of them like you said.
                        But every time i do a modded apk or something like "framework" and restard the tablet .
                        Than every time i have this callibration after startup.
                        En must i recovery again
                        </form>
                          Exactly the same happened to me, renaming didn't fix it either.
                          Bob suggested using CWM to format data and cache, that didn't work to a reflash and restore was in order.
                            ok, short update. Did some network changes at home - re-tested, got average speeds around 6-7mbps dl, youtube working fine, iplayer still crap!
                            Great stuff snakekiller, sorry for the scare! Turned my "super" hub into modem only, re-attached old belkin & got good speed. Range on 10b still less than 7g2, but getting happier.
                            One strange thing - after setting up to my new wifi network at home whilst i have a full signal (according to settings) the icon on the taskbar is now empty?? Will reboot, but any ideas guys?
                              And deleting all 3 is the same damned
                              Sow i must wait for bob's final version to mod something
                              </form>
                                One last thing before I crash - hope someone can help here. It's a little strange.
                                When playing around with the wifi, etc the tab was showing up as having 61% battery. With the loss of the signal icon showing I decided to reboot - to then find I had 16%? I'm not sure if this is a battery stat error, something else? Just after the hoo-hah with the 7g2 showing accurate battery usage i'm a little nervous about this.
                                Anyone had the same / similar experience? Any ideas?
                                The only difference i've made to Bob's rom is adding Snakekiller's latest modified build.prop
                                Thanks as always
