I needed to do it because of some of the bugs in the latest release from Minix on 5/30.
For instance the Gplay update bug. All fixed
So even though this is my first and is 1.0, your getting all the fixes, updates, enhancements that I have learned since doing S802 A9 ROMs starting with the Tronsmart S89. So you have everything in it I know so far.
Enjoy!
DO NOT just copy this download ZIP to SDcard and expect it to work!
UNZIP it and read the README for instructions!
__________________________________________________ _______
Features and release notes for my 1.0 ROM:
1) Properly rooted using SuperSU. What does properly mean?
Android 4.4.2 requires SU to be running as a daemon now. There are many ways to run this as a daemon.
Most roots so far are using a install-recovery.sh script or if init.d is enabled, a init.d script.
This means you could lose root if messing with these scripts which some rooted apps do!
What I have done is started the daemon in init.rc thus eliminating the need for boot scripts!
This took me a while to learn to do! Enjoy a BETTER ROOT!
2) Updated Google framework and Play Store core files. The ones in the stock ROM were out of date.
On first boot NOTHING will need to be updated once you logon to Google Play.
That is as of this date.
This does FIX the Google Play update issue in the current Minix ROM
3) Debloated of junk APPs and Google Apps you can get from Google Play.
I did remove XBMC and other pre-install APPs as well except AirPin Pro.
I like a CLEAN ROM that you the user can setup the way you want.
Having APPs in /system leaves that junk in there forever (unless you delete them by hand with a root explorer).
4) init.d support was already in this ROM but I cleaned it up to work so it uses the correct init.d folder.
5) Build.prop edit to open up the Google Play store to APPs that normally say "not compatible".
I am spoofing a Samsung device (Nexus 10) that will show almost any APP as compatible.
This should also allow Netflix HD but I have not tested it.
Your device will show up in google play as Nexus 10 device not a X8! Understand this please.
I also left the original build.prop in the ROM called build.orig.
If you want to go back, just use ES FIle Explorer or a root file explorer and rename build.prop to build.old
Then rename build.orig to build.prop.
Go into settings, apps, all and go into the Google Play app. Clear the cache and data.
Reboot! You should be back to showing up as a X8.
7) I added a reboot APP that will allow optional reboot options like reboot to recovery for easier updates.
8) Carrier spoofs for better APP compatibility.
9) The usual tweaks I do for better performance e.g. TCP buffers sizes, etc etc.
10) Added bonus! CPU fixer patches!
In this ZIP is a CPU_fixer folder. These zips can be used to adjust your minimum CPU frequency and Governor.
See the README.txt in that folder for an explanation and how to install them.
11) XBMC Notes:
I did remove the Minix XBMC.
This is because it wont work on my ROM due to build.prop edits spoofing a Nexus 10.
However if you want to use the Minix XBMC then copy it from the stock ROM BEFORE you flash this ROM!
Use EX File Explorer and in the stock ROm copy the XBMC app from /system/preinstall folder to your sdcard.
Then using instructions from #5 above, rename the build.prop files to change you back to a X8 and reboot.
Then just install the XBMC APP from sdcard.
Or just edit the build.prop file using EX File explorer and change this line:
ro.product.model=Nexus 10
to
ro.product.model=NEO-X8
Alternative!!!! Forget the Minix XBMC and use a special one made for the S802 by Oman.
Get it here:
Maybe later I will patch the Minix XBMC to work on my ROMs.
OK so here is the download!
READ the README.TXT in the zip for instructions!
ROM -> Minix Neo X8 - Finless 1.0 ROM (343 megs)
UPDATE! 6/7/2014
Device ID FIX patchers available. Go to this post to get info about them and downloads:
http://www.freaktab.com/showthread.p...l=1#post190184
UPDATE! 6/8/2014
Patched Minix XBMC for Finless ROM 1.0. Go to this post to get info about them and downloads:
http://www.freaktab.com/showthread.p...l=1#post190286
Enjoy,
