Finless 1.0 ROM for the Minix X8
Originally posted by Scherzzo View PostI got stuck on the welcome screen, any ideas? I added the rom using method 2, then I got to the welcome, language, screen and network but couldnt do anything after that????
Also you will notice every boot it takes a few seconds for the sound to work. So always give it a few seconds to settle down after booting.
Originally posted by 108mob View PostOkay going to flash your rom and patch which of the four patch id are you running ? thanks Bob
Questions on CPU Cores & Temperatures
What is the normal operating range of temperatures of the CPU Cores ?
I seem to be getting temperatures of 60c when idle and I wanted to know if this seems a normal temperature.
Also i noticed that CPU0 and CPU1 are normally active while CPU 2 and CPU3 are mainly offline.
I presume this is due to the hotplug scaling as i had flashed the following zip file.
cpu_fix_stock_lf.zip
Min Frequency 96000 (this is back to stock).
Max Frequency 1992000
Scaling Hotplug
Thank you.
Originally posted by cooldudey View PostWhat is the normal operating range of temperatures of the CPU Cores ?
Scaling Hotplug
Thank you.
Based on what we know so far yes the hotplug keeps the last 2 CPUs off until they are needed. This is why the CPU patches I provided set it to interactive. The low CPU some have said effects the launcher lag and possibly other apps as it takes a little time for the speed to ramp up thus the idea is set the low CPU to 816 or higher so it does not have to ramp up from such a small limit like 96.
HOWEVER, people have reported heat issues on some boxes! That is the CPU is slowing down to control CPU temps which may not be valid! I do not expect to see that on the X8 though. It appears to be only on early M8's and S89/S82's. For me all of my S802 boxes have no CPU slow downs for heat issues but other M8 and S89 users report issues even on stock! We do not know why we are seeing differences like this other than "RUMORS" of some AML processors having this problem.
My suggestion would be to try them and watch what your temps do. No one I know has fried their box using these but again USE AT YOUR OWN RISK is all I can say about it.
Thanks for your explanation as I understand this better now.
So basically these patches are just for increasing the minimum frequencies to eliminate lag.
I have not noticed much lag really so i am just using the default values with the hotplug governor.
What temperatures do you get in idle mode ? Does 60C sound too high ? I have no ideas what range my CPU should be in.
Thanks again.
Originally posted by Finless View PostBased on what we know so far yes the hotplug keeps the last 2 CPUs off until they are needed. This is why the CPU patches I provided set it to interactive. The low CPU some have said effects the launcher lag and possibly other apps as it takes a little time for the speed to ramp up thus the idea is set the low CPU to 816 or higher so it does not have to ramp up from such a small limit like 96.
I have not really used any temp apps to monitor what's is going on. Reason is some think they do not work correctly. I go by how hot my CPU feels with the cover off.
But there are a LOT of discussions about it here:
And some here:
http://www.freaktab.com/showthread.p...-cool-it-down-)
Do some reading and see what you find. I don't think 60C internal core temp is a problem but is that real?
Originally posted by Scherzzo View PostI installed the rom last night and installed omans xbmc and noticed it was more laggy than the minix version. Any suggestions to improve the lag.
?RK3288 Devices
- Overview BOX (LINK !)
There are currently 4742 users online. 1 members and 4741 guests.
