Finless 1.0 ROM for the Minix X8
Originally posted by Rooverz View PostCan someone comfirm netflix hd 1080p is working with this rom?
Is it possible te get 1080p 24hz (or hz) working?
No 1080p 24Hz (Android limitation).
Originally posted by cooldudey View PostWhat temperatures do you get in idle mode ? Does 60C sound too high ? I have no ideas what range my CPU should be in.
Thanks i will check it up.
I used an application called Android Tuner and that is reporting around 60c for CPU temperature. However i read the previous post and Wek05 reported a temperature of 30c from XBMC so i checked in XBMC and its reporting exactly 30c at Idle time. So perhaps its just Android Tuner giving me a very high temperature and i have nothing to worry about.
I was just worried that my unit might be overheating but that seems its not the case then.
Thanks again.
Originally posted by Finless View PostI have not really used any temp apps to monitor what's is going on. Reason is some think they do not work correctly. I go by how hot my CPU feels with the cover off.
But there are a LOT of discussions about it here:
And some here:
http://www.freaktab.com/showthread.p...-cool-it-down-)
Do some reading and see what you find. I don't think 60C internal core temp is a problem but is that real?
Actually i did some further investigation and it seems that the temperature XBMC is reporting of 30C/86F is in fact the battery temperature which does not exist on this unit. Seems like this temperature is always static at 30C/86F.
I found another app called CPU Temperature by Mooncakes on the PlayStore and its reporting exactly the same temperature as Android Tuner was which is around 60C in my case.
Can someone Install CPU Temperature and see what temperatures are reported to you.
Thanks again.
Originally posted by WeK05 View Post... reported in XBMC was 86F/30C (don't know whether this is correct).
Try 'Cpu Temperature'
RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostI think it is as in many other app's the battery temperature => useless
https://play.google.com/store/apps/d...yanyan.cputemp
I just tried a few of these apps. The mooncake CPU temp app works the best I can tell. All theother apps the temp is always never changing. CPU temp you can see the trend of temps with CPU usage so I am thinking it is working. My high is 150F and low is 102F.
Originally posted by HardwareGuru View Postofftopic:
I want to thank you for this rom!
Starting with AML roms...
I am learning a lot from it
Originally posted by HardwareGuru View Posti have send you a beer to enjoy next weekend
cheers mate"Pzebacz im, bo nie wiedzą, co czynią"
I am learning a lot from ...
+1RK3288 Devices
There are currently 2260 users online. 7 members and 2253 guests.
