I am trying to avoid using a mounter such as this or stickmount because they do not work right due to the fact that android auto mounts the drive as well.
For example, if stickmount is used it will mount to /sdcard/USBstorage/SDA1, while android is mounting the same drive to /storage/external_storage/SDA1. Becuase of this dual mounting, weird crap happens. I had issues with the drive being read only when dual mounted and other weird issues.
Furthermore, where the drive is being mounted now (/storage/external_storage/SDA1) is a horrible mount point. Many apps reject it....one being Poweramp which is one of my favorite players which i now cannot use. PlayerPro sees that location and works thankfully, but this mount location needs to be fixed.
Ultimately it would be great if either:
1. The mount point for USB storage was moved to /mnt/usb and NTFS and exFAT support were introduced, OR
2. There existed an easy method of completely disabling Android's defualt USB mounting so that I can use something like Stickmount without the issue of multiple mount points for one hard drive.
I beg that someone fixes this someday soon
