Cube U9 GT2 And Compatible ICS Finless ROM 1.4
    UPDATE Aug. 11 2012
    I have updated the ROM to include the proper KEY COMBINATION in the parameter file so you can get into ClockWork using the hard buttons. See the post below about it.
    The ROM download link below has been updated to version 1.4a
    New file name is: cube9gt_ics_finless14a_ext4_cwm.zip
    _______________________
    OK folks, Daman has been testing my new (ICECUBE) ICS ROM so it is ready for others to try.
    Also the compatible tablets listed below(Only Tested on the Cube as yet)
    Yuandao N90 Ricatech tab 10-6 Visture V2 Easypad 970 Cresta CTP888 Viewpia TAB-110 CHUWI V9 Tenket TKP1004
    Features:
    All File systems converted to EXT4
    EXT4 ClockWork Recovery
    (Use Power And Volume - Button)
    Based on Stock Android 4.0.4
    Stock AOSP ICS system (no bloat).
    Google Play Store
    Full Root latest Superuser su
    System storage increased to 2gb!
    English keyboard and language
    Set up wizard on first flash
    ROM Cube 9GT-2 - ICS - Finless 1.4 EXT4 CWM (260 megs)
    Enjoy,
    Done, thanks.But now I'm on vacation and I must wait until next week for testing.
    Sended from ace 2
      '' OOPS nothing to download, bad filename? ''
      that is the message after click on the link
        Make sure you are logged in and have the box remember me selected when you log in. Just tested link it is working
        Sent from my SK17i using Tapatalk 2
        </form>
          No download
          I just logged in with remember me checked and get the same error.
          Edit: Here is what it links to: http://video.freaktab.com/?subpath=f...4_ext4_cwm.zip
          Here's the working link from another thread: http://video.freaktab.com/?subpath=finless/cube&filename=cube9gt_finless_15.zip *** Sorry, this is a Gingerbread rom ***
            doesn't matter how I logged in I can't use the link. Before I sent my previous message I checked all the options...
              The link is working for me try clearing your browser cache and try again
              </form>
                I just cleared cache in my portable Firefox, and still get the same error.
                  Sorry about this I will get bob to check the link.
                  </form>
                    IT will download from tapatalk but not a browser, wtf
                    says bad filename
                    </form>
                      I fixed the link. Daman, do not edit my posts with tapatalk. It is converting the URL path symbols and breaks the link.
                        Sorry man
                        My fault guys I apologize. Link now up and running like
                        It was this morning till I broke it.
                        A lesson learned
                        </form>
                          I have Wayteq xtab-100is which is supposedly a cube u9gt2 variant, and Evolution 2.3 rom works fine...
                          So is it safe to try this rom also?
                          Also, big tnx to all involved with creating this rom
                            Yes should be fine
                            </form>
                              OK folks, Daman has been testing my new Cube 9 ICS ROM so it is ready for others to try.
                              Congratulations, Bob, on this fine ICS Cube rom with Clockworkmod recovery! I have installed it and it is working well. I know cwm is not important to everyone, but when you test and flash roms it is indispensable. Here is what I've done as far as customizing, in case it helps someone.
                              1. I couldn't get the cwm launch keys to work, so I added "COMBINATION_KEY: 0,6,A,7,0" to your parameter file and reflashed just parameter and recovery. (Rom Manager's "Reboot to recovery" option and the Titanium Backup widget should both work as well).
                              2. I like ADW Ex launcher, but for some reason all the widgets appear inside large black boxes, so I decided to stick with the stock launcher, which works fine.
                              3. I installed the Mx video player and it played my full HD video without any stuttering. YouTube app is working great also.
                              4. As with many ICS systems, I couldn't find a Contacts (now "People") icon, so I installed "Any Cut" and created a "People" icon to add to the Google apps folder on the home screen.
                              It's great having a good Cube rom with cwm, at last. I can see this rom overtaking many of the older Android 4.0.3, ext3 Cube roms. Just have people install cmw, and they can back up their current rom, then flash this one!
