I tried flashing evolution 3.0 had the issues there. tried stock 1.10 but that too much chinese to be able to tell much but it did seem to restart on its own once there. Now I am back to 1.5. It was most stable when the problems started. upon further review this one doesnt have internal sd but on board nand flash, correct? I noticed a message while starting checking memory- sd card damaged. I dont have a ext sd installed while flashing.
Cube U9 GT2 And Compatible ICS Finless ROM 1.4
I never really had that issue but I almost never use it while plugged in. It is the original and I have seen the occasional spark while plugging it in. (I've read about the charger issues before). I did this time based on recommendation to flash that way.
How to update?
Hi
Can anyone give me simple instructions on how to install this?
I have a Yuandao N90 and have a couple of problems with it:
1) the keyboard has always been a bit laggy but I've out up with it
2) my son has managed to do something that's switched the sound off and I cannot switch it back on again.
So.... I've decided to try an updated version of Android to see if it fixes either/both of the problems.
I have copied the ZIP file to the desktop of my PC - what do I need to do next?
Thanks in advance,
Higs
Re: Cube U9 GT2 And Compatible ICS Finless ROM 1.4
Thanks in advance,
Higs
Sent using Tapatalk 2 from Sony Xperia Mini Pro - Ics 4.0.4Please consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
Try a benchmarking program that reads and writes to /data instead of just SDcard. I think you will find the EXT4 files system will show a big benefit there!
I believe the Evo ROM is still using EXT3 and pretty sure it doesnt have CWM?
...and I'm shure that our test results are not valid.
I have for the finless rom around 2350 points too, but someone else on androidhilfe.de had only around 2150 points for the evolution 3. Thats not much difference, but finless rom is faster.
Bob, I have noticed a problem in the german thread to your rom on androidhilfe.de.
If I install google chrome or opera mobile, it will first slow down and then crash or freeze after a while. Only the stock browser is bit better, but not very much.
A reply to thread on freaktab will slow down the rom nearly to freezing.
Has someone an idea, what the cause might be?
Well nothiing I did should cause that I can think of. Remember I used the standard Cube AOSP ICS when I made this ROM. All I did was root it, convert it to EXT4, added full play XML patch files, and CWM. Possible the build.prop? I did not modify that. Maybe the patch XML files to give more apps in Play store is causing it?
Do other Cube ROMs (like the Evo) have this problem?
Is it only one person having this or everyone?
I do know people having a lot of problems with Chrome on other ROMs other than Cube. If I had more details I could look into it.
I have a few posts with browser problems.
I'll check deeper for more details and report.
Here comes at first logcat.
21:17:43.949 <1423>[dalvikvm]: VFY: unable to resolve virtual method 769: Landroid/webkit/WebView;.addPackageNames (Ljava/util/SetV
21:17:44.309 <1423>[dalvikvm]: VFY: unable to resolve virtual method 768: Landroid/webkit/WebView;.addPackageName (Ljava/lang/StringV
21:17:44.309 <1423>[dalvikvm]: VFY: unable to resolve virtual method 795: Landroid/webkit/WebView;.removePackageName (Ljava/lang/StringV
21:17:44.319 <1423>[dalvikvm]: VFY: unable to resolve virtual method 4304: Lcom/ninesky/browsercommon/ui/NSWebView;.getZoomButtonsController ()Landroid/widget/ZoomButtonsController;
21:17:44.319 <1423>[dalvikvm]: VFY: unable to resolve static method 523: Landroid/text/IClipboard$Stub;.asInterface (Landroid/os/IBinderLandroid/text/IClipboard;
21:17:44.429 <1423>[Settings]: Setting android_id has moved from android.provider.Settings.System to android.provider.Settings.Secure, returning read-only value.
21:18:58.579 <132>[ActivityManager]: ANR in com.ninesky.browser (com.ninesky.browser/.ENBrowserActivity)
Reason: keyDispatchingTimedOut
Load: 3.37 / 3.0 / 1.75
CPU usage from 34429ms to 0ms ago:
77% 1423/com.ninesky.browser: 76% user + 0.8% kernel / faults: 4493 minor
9.4% 771/com.bartat.android.elixir: 9.2% user + 0.2% kernel
1.8% 132/system_server: 1.2% user + 0.5% kernel / faults: 11 minor
1% 13/kworker/0:1: 0% user + 1% kernel
0.8% 937/kworker/0:3: 0% user + 0.8% kernel
0.6% 54/rknand_buffer: 0% user + 0.6% kernel
0.2% 80/surfaceflinger: 0% user + 0.1% kernel
0.1% 1160/kworker/u:3: 0% user + 0.1% kernel
0.1% 199/com.android.systemui: 0.1% user + 0% kernel / faults: 7 minor
0% 14/kinteractiveup: 0% user + 0% kernel
0% 41/galcore daemon : 0% user + 0% kernel
0% 61/mtdblock6: 0% user + 0% kernel
0% 79/rild: 0% user + 0% kernel
0% 130/flush-31:6: 0% user + 0% kernel
0% 274/com.google.process.gapps: 0% user + 0% kernel / faults: 2 minor
0% 289/com.android.inputmethod.latin: 0% user + 0% kernel / faults: 2 minor
0% 443/RTKTHREAD: 0% user + 0% kernel
0% 559/com.google.android.talk: 0% user + 0% kernel / faults: 3 minor
0% 714/com.android.vending: 0% user + 0% kernel / faults: 7 minor
92% TOTAL: 90% user + 2% kernel + 0.1% softirq
CPU usage from 651ms to 1181ms later:
83% 1423/com.ninesky.browser: 81% user + 1.8% kernel / faults: 6 minor
83% 1453/WebViewCoreThre: 83% user + 0% kernel
7.5% 132/system_server: 3.7% user + 3.7% kernel / faults: 2 minor
3.7% 168/InputDispatcher: 0% user + 3.7% kernel
1.8% 767/Binder Thread #: 1.8% user + 0% kernel
2.7% 771/com.bartat.android.elixir: 1.3% user + 1.3% kernel
2.7% 904/WebViewCoreThre: 2.7% user + 0% kernel
1.8% 13/kworker/0:1: 0% user + 1.8% kernel
1.8% 1160/kworker/u:3: 0% user + 1.8% kernel
100% TOTAL: 92% user + 7.5% kernel
21:19:02.809 <289>[InputConnectionWrapper.ICC]: Timed out waiting on IInputContextCallback
21:19:06.479 <132>[InputManagerService]: Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$ Proxy@413599a8
21:19:07.539 <289>[InputConnectionWrapper.ICC]: Timed out waiting on IInputContextCallback
21:19:09.539 <289>[InputConnectionWrapper.ICC]: Timed out waiting on IInputContextCallback
21:19:11.539 <289>[InputConnectionWrapper.ICC]: Timed out waiting on IInputContextCallback
21:19:13.609 <289>[InputConnectionWrapper.ICC]: Timed out waiting on IInputContextCallback
21:19:15.609 <289>[InputConnectionWrapper.ICC]: Timed out waiting on IInputContextCallback
21:19:17.609 <289>[InputConnectionWrapper.ICC]: Timed out waiting on IInputContextCallback
21:19:19.609 <289>[InputConnectionWrapper.ICC]: Timed out waiting on IInputContextCallback
21:19:20.239 <132>[ActivityManager]: Activity pause timeout for ActivityRecord{41386308 com.ninesky.browser/.ENBrowserActivity}
21:19:21.669 <289>[InputConnectionWrapper.ICC]: Timed out waiting on IInputContextCallback
21:19:23.549 <1423>[IInputConnectionWrapper]: getTextAfterCursor on inactive InputConnection
21:19:23.549 <132>[InputManagerService]: Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$ Proxy@413b9b20 (uid=10051 pid=1423)
21:19:23.879 <1423>[IInputConnectionWrapper]: setComposingText on inactive InputConnection
21:19:23.879 <1423>[IInputConnectionWrapper]: getCursorCapsMode on inactive InputConnection
21:19:24.079 <1423>[IInputConnectionWrapper]: showStatusIcon on inactive InputConnection
21:19:24.319 <1423>[webcoreglue]: updateFrameCache: pending style recalc, ignoring.
21:19:40.589 <132>[InputManagerService]: Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$ Proxy@412e5690
21:19:47.809 <132>[InputManagerService]: Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$ Proxy@41355550
21:19:49.639 <132>[ResourceType]: Skipping entry 0x10a0000 in package table 0 because it is not complex!
21:19:49.649 <132>[ResourceType]: Skipping entry 0x10a0001 in package table 0 because it is not complex!
21:19:55.189 <132>[InputManagerService]: Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$ Proxy@4137dd78
21:20:35.909 <639>[Gmail]: Successful index run, cancel next scheduled index run
Okay, I have checked evolution 3(#18b).
I have the same problem with reply to a thread on freaktab and only on freaktab.
pressing the reply to thread button, then my tablet goes into slow motion and the tipped letters are coming delayed after more than 3 seconds.
It seems to be no android browser problem. On xda and androidhilfe.de the reply works fast and propper without slowing down.
Btw the new version of evolution 3 rom is much faster than 2.3.
Antutu says on my easypad with testing internal sd
ca. 2350 finless ICS
ca. 2400 evolution 3(#18b)
Evolution rom don't like opera and chrome browser too. ---Freezing
Maybe I go better back to gingercomb. This rom runs like hell.
JDfense
PS.:
Finless gingercomb made antutu with 2440, but the feeling is much faster. That proofs that the benchmark is only a hint.Last edited by JDfense; 31 August 2012, 22:39.
thanks bob
your rom i test on cube u9gt2
so far i test is more better that evolution rom
from i test 2.3 version and this 4.1 rom
i very looking forward your job..
only one thing this for game
for backstab hd i go install complete plus sd data,when i go in movie ok after that jump back to main screen.
Originally posted by aasgevi View PostI have earlier installed ROM using LiveSuit. When I connect my unit the driver for LiveSuit installs. (USB Device VID_1f3a_PID_efe8). When I try to update driver pointing at drivers folowing Finless ROM 1.4a it will not install. I am using Win7_64bit.
In the firmware folder is a read me file to install drivers. Once installed use the rockchip flashing tool in the firmware folder.
</form>
Evolution 2.3 is really slower.
JDfense
There are currently 2951 users online. 1 members and 2950 guests.
