MINIX X5 android 4.4.2 KitKat ROM (beta)
I have finished the KITKAT rom for the Minix X5. All is working great (HLS streaming, Youtube, XBMC).
You can download the ROM (720p AND 1080p) from the first page in about 10 minutes.
Oh and if you like it you can donate using the donate link in the first post.
If you notice any bugs let me know!
Originally posted by karel View PostWhy thinking about failure? But if it fails it's no problem to go back to JB.Netflix without messed-up screen
In the previous release you placed the Mele F10 keylayout file. In this release it is missing so for example my Home button is not working. As many Users are using the Mele (great Mouse) Can you please add it ? Assume it is not rooted.
Will try to do more test tomorrow and keep you updated. Thanks for your work on it.!
KAR
Originally posted by KAR View PostNot specially a failure but for example if some apps are not working and i want to go back. Anyway I have installed it and it is looking goodNetflix without messed-up screen
KAR
Re: MINIX X5 android 4.4.2 KitKat ROM (beta)
Originally posted by karel View PostDid you change back the permissions of the key file after copying? The file should have the same permissions as the other key files. And also a reboot can help.
Thx kar
Originally posted by KAR View PostPermissions are fine rebbor does nog help. Found another issue. Sleep does not work. When i put it manual in sleep mode it does not wake anymore (nog even with the power button).
Thx kar
Later on I will have a look at this issue.
KAR
Change "key 102 MOVE_HOME" to "key 102 HOME"
There are currently 2226 users online. 1 members and 2225 guests.
