MINIX X5 android 4.4.2 KitKat ROM (beta)
Originally posted by KAR View PostHij Karel, can you check this ?
Within a month I will release a new version with some fixes like the changing LAN mac address and support for additional remote controls. AND a new SPMC version supporting the rockchip VPU using libstagefright (hardwaredecoding) which was broken in the last two gotham SPMC versions.
Re: MINIX X5 android 4.4.2 KitKat ROM (beta)
Originally posted by karel View Post8Gb for the apps is a small edit in the parameter file. You can do it yourself using the "RK3xxx Firmware Tools by SergioPoverony" and extract the firmware and edit the parameter file using the included editor and then rebuild the firmware.
Thx just tried but nu luck.. Somehow it keeps 4 gb.
Thx Ronald
Thx RonaldSo I have your FW now with the 8 GB app partition. In case someone need it the 8gb 720p can be found here (Install at your own risk):
X5_KitKat_720p (8GB)
Thx,
KARLast edited by KAR; 24 July 2014, 10:37.
How to from KitKat to JB
Originally posted by KAR View PostWorking nowSo I have your FW now with the 8 GB app partition. In case someone need it the 8gb 720p can be found here (Install at your own risk):
Thx,
KAR
Can any one help to resolve this .
Originally posted by zykhan View PostHi, I Flash the Kit KAT FW onNeo X5, now I wants return back to 4.2, every time I flash older version , it stuck in Recovery Mode . loading show successful.
did you solve this? i know if you flashed kitkat you have to re select the loader in the stock rom to go back to jb just make sure loader for jb selected iit come in few roms.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by Cmin View PostThank you for this Rom, it works just great. There is only one thing that i really miss. is it possible to make the camera work? when i open the camera app, i see: can't connect to the camera.
log:
https://app.box.com/s/qhk4p5n2nkitnscvqx6a
AW: MINIX X5 android 4.4.2 KitKat ROM (beta)
Originally posted by karel View PostCould be that it is not recognized. What is brand/type is you camera? I can have a look if it is supported in the kernel sources.
EDIT: logitec c 920Last edited by Cmin; 07 August 2014, 20:51.
There are currently 2035 users online. 1 members and 2034 guests.
