Hi there. Love this rom and SPMC runs great except live streams from Navi-X, I haven't been able to play a single one yet).....I was previously on Finless 1.3 ROM and netflix from Play Store ran perfect. On this Kitkat rom there is a severe audio/video sync issue. Is there something I can do or does someone have a netflix apk for a good working version? Thanks.
MINIX X5 android 4.4.2 KitKat ROM (beta)
Netflix and Navi-X?
Originally posted by karel View PostWithin a month I will release a new version with some fixes like the changing LAN mac address and support for additional remote controls. AND a new SPMC version supporting the rockchip VPU using libstagefright (hardwaredecoding) which was broken in the last two gotham SPMC versions.
I use my X5 to watch football streams using ethernet connection, do you recommend me to use this Kitkat or 4.2.2 ROM?
Originally posted by arkashkin View PostHi Karel,
Is the any chance that you will make the headphone jack work?
Originally posted by hoangan123 View PostNot seach bluetooth headphone sony ericsson. I hope you fix last version. Thanks. when have last version. Can't waiting...
Originally posted by KAR View PostStandby does not work. Do you have a fix for this?
For the rest it is pretty stable. And sound output via synology audio is crappy. Also is there an image for the mini ?
Which patches do you have b
Available?
Thx kar
Install synology audio on your phone/tablet and use XBMC (on the synology) as external player. I use my own compiled version of KODI which has no audio issues and enables passthrough.
I made a script to get a fixed MAC address, which is useful when using portforwarding (example sickbeard updates on XBMC).
I added additional remote controls .ko files.
The mini has different hardware (which i don't have). Meaning a different .config is needed to compile a kernel for the mini. So no image available.
Re: MINIX X5 android 4.4.2 KitKat ROM (beta)
Originally posted by karel View PostI disabled the power / standby key in the remote .kl file. Meaning standby doesn't work. The advantage is that accidentally pressing the powerbutton want have a negative effect.
There are currently 3081 users online. 5 members and 3076 guests.
