MINIX X5 android 4.4.2 KitKat ROM (beta)
    Originally posted by karel View Post
    Did you change back the permissions of the key file after copying? The file should have the same permissions as the other key files. And also a reboot can help.
    Looks fastreboot does not fix the issue, after plugging out the power cord the mouse works now with the new keylayout.
    Found some other issues:
    So found so far:
    - Sleep not working
    - 1080 play back in Beyond XBMC >> hurrible... looks like watching a movie in slomotion.
    - Mele Mouse keymap << FIXED>>
    Thx,
    KAR
      Originally posted by KAR View Post
      Looks fastrebood does not fix the issue, after plugging out the power cord the mouse works now with the new keylayout.
      So found so far:
      - Sleep not working
      Thx,
      KAR
      For 1080 play back use the included SPMC and use libstagefright for hardware acceleration.
        For now it's only the X5. (I don't have a G4 to test the kernels.)
        I think the kernel should be the same as X5, but with different Wi-Fi driver and no Bluetooth.
        I'm ready to test it for you.
          I am sorry to saybut I test it and 1080p movies are stuttering in xbmc and sometimes the logitech keyboard dont work
            Originally posted by Pampam View Post
            I test it but the 1080p movies are stuttering in xbmc and sometimes the logitech keyboard dont work
            I have tested some 1080p movies (x264) and they play fine using the 720p version of the firmware. Did you use the included SPMC?
              Re: MINIX X5 android 4.4.2 KitKat ROM (beta)
              Yes I use spmc but I use also the 1080p firmware
                Have you tried MX player? Does that work? On my X5 MX player also runs fine.
                If it doesn't work on the 1080p firmware you should really think about going back to 720p firmware.
                  Hi Karel,
                  SPMC works much better indeed for 1080 p movies.
                  regarding the sleep function do you have any idea? Also Might be a stupid question but how can i remove Icons from my screen, normally select and move to the X Area but now it does not appear.
                  KAR
                    Karel, can you tell me what config file did you use for Minix X5? Did you make any changes to the source to get the kernel working?
                      thanks great !. when have android L on x5
                        thanks great !all working good. when have android L on x5
                          Hi Karel, SPMC works fine with 1080p. any idea about the Sleep Function and the Icons to be removed from the screen ?
                          No reboots so far really great!
                          Thanks!
                          KAR
                            Headphone not working
                              Karel, any plans for the mini?
                              Thx kat
                                Enabling the headphone in the kernel gives a conflict with the HDMI and Optical out. Therefore i kept it out.
