Pipo M8HD RileyROM 1.9 KitKat
Originally posted by utal View PostDon't know if it was the reason for 3g is working for me, but I'm using a oc kernel with the boot.img. 3g was working good with the last version 1.8. Can't help more :-(
Sent from my Xiaomi using Tapatalk
has any one got a link to the orignal firmware this is based on so I can test out the 3g
The main difference between 1.8 and 1.9 was that this newer version was based on official factory firmware. 1.8 was adapted from a ROM created by Chinese developer Edge Xuan (many thanks to him) from the exact same factory firmware. If 3G works on 1.8 and doesn't on 1.9...it's possible that Edge Xuan added something that I missed.Randy
Originally posted by rrileypm View PostThe main difference between 1.8 and 1.9 was that... ...it's possible that Edge Xuan added something that I missed.
But it may be Android 4.2 JB. I am not sure.
BR.
Vs: Pipo M8HD RileyROM 1.9 KitKat
Originally posted by rrileypm View PostI wasn't aware there was a 3G version of this tablet. Does anyone else have 3G?
Missing the unstable Android 4.4 3G drivers makes this better.Last edited by sikke; 18 September 2014, 22:24.
Hi, I'm trying to get 3G with external usb modem on my wifi only tablet
I turn off wifi, reboot.
Check data enabled and data roaming.
But when I try to search for network operators, I 'm getting error while searching operator.
And when I go to Access Point Names, I get none and can't save a new one
I'm just testing this functionality, maybe something is missing too
Originally posted by stevejc View PostHi, I'm trying to get 3G with external usb modem on my wifi only tablet
Originally posted by spawnofdonny View PostNot all dongles will work http://www.pipo.cn/En/index.php?m=Co...&id=263&type=3
Originally posted by KabarAzab View PostMy tablet has internal 3G and that's what troubling me that I cannot get 3G working. This I have asked OP. Now hopefully, he will do comeback with some solution.
Originally posted by spawnofdonny View PostI think it could be something to do with the bootloader I have tried v2.13 and I can get a connection for about a minute every so often, so I am going to try some different second gen bootloaders tonight if I get time
BR.
Originally posted by KabarAzab View PostCan you guide me more about bootloaders? Which version and where should I get different bootloaders to test?
BR.
I used RK3188Loader(L)_V2.13.bin and the current rom is using RK3188Loader(L)_V2.10.bin
Originally posted by spawnofdonny View PostBe very careful you could brick your tablet if you flash the wrong bootloader so if you don't know what you are doing please leave it for some else to try and wait for results
http://www.arctablet.com/blog/forum/...-rk3188loader/
BR.
There are currently 2400 users online. 0 members and 2400 guests.
