Pipo M8HD RileyROM 1.9 KitKat
Originally posted by stevejc View PostYes, as I 'm trying to reverse engineering settings.apk I see that as you get mobile data, you will have this.
So.
This may help with dongel problems you are having http://forum.xda-developers.com/show...utmk=126052110
Originally posted by spawnofdonny View PostI just remembered i had changed phone tweaks settings on gravity box about the same time which is more likely to be reason why i am getting better connections sorry for the confusion
And now I have spent my one day plan !
I dont know if anyone will find this useful but i have made a radio logcat from my tablet radio logcat.zip
Originally posted by utal View PostFrom my side I'm not an expert, just followed the steps to install the ROM. I always had 3g on every rom I installed.
Sent from my Xiaomi using Tapatalkhttp://www.freaktab.com/showthread.p...l=1#post154472 so how did you get it working
Re: Pipo M8HD RileyROM 1.9 KitKat
Ups, forgot that one, I rarely use 3g.. Sorry for the wrong info
Originally posted by spawnofdonny View PostEvery rom?http://www.freaktab.com/showthread.p...l=1#post154472 so how did you get it working
Originally posted by petyaaa6 View PostVIPER4FX for me weird a bit. Phone speaker's eq works, When the headphone plugged in,but headset's not.
Try this. http://forum.xda-developers.com/show....php?t=2355182
I am not sure if this the right place to ask the question but i have cracked my screen and i am struggling to find the replacement part
All can find is this web site http://technorio.prom.ua/p39993807-o...krin-dlya.html but they don't deliver to the UK
Thanks in advance to anyone that can help
I´m spaniard so my english is very poor.
Sorry I write a long text about a problem but now the problema is solve.
Any way I want share this trick that I discover for the hard way. If upgrading or downgrading the Tablet is brick; before to try other Intricate method, try this.
Press the reset hole to turn off the table, conec the tablet to PC with USB wire. plung the charger. This turn on the tablet automicatilly in recovery mode, ready for flash again.
There are currently 2011 users online. 1 members and 2010 guests.
