Well,fifa 14 has statusbar :/
Pipo M8HD RileyROM 1.9 KitKat
First backup your rom !
Then install xposed Framework, reboot
Then in the module list search for gravitybox KitKat, install it and reboot.
Finally configure Display tweaks, Expanded desktop mode and choose immersive
You will see that gravity box adds many features
Originally posted by stevejc View PostGravity box is a module of xposed Framework : see here : http://forum.xda-developers.com/xpos...gelog-t2714053
It sounds to me a bit complicated, or i just dont understand clearly what extras it could give.
Another thing: now the tablet seems charging really slowly: from 3:30am to 8:30am , from 5%to 84%.
Or,today, in more than 2hrs 10% (from 84 to 95%)
Is it ok?
Originally posted by petyaaa6 View PostIt sounds to me a bit complicated, or i just dont understand clearly what extras it could give.
Is it ok?
or here: http://forum.xda-developers.com/show....php?t=2504127
Last version of Xposed framework apk : http://dl.xposed.info/latest.apk
Is it ok?
But this is a huge battery so 5 hours is normal !
do you use the original power supply : I recommend it.
Originally posted by stevejc View PostFor battery, try do not let it plugged more than 5 hours. I see some time after reaching 100 %, percentage decreases !
Thank you!
Well, yes i use the original supply :/
And somehow,i feel like the window opening(open browser,or fileexplorer, loading a page in browser) feels like a lil bit laggy. Or notnlaggy, but like not enough fps,like few frames woukd missing.
In fifa14 i feel a lil fps dropp compare to stock.
Originally posted by stevejc View PostYes I notice the same about fps.
In epic citadel benchmark we get only 30 fps compared to 43 fps with JB !
Don't know why maybe something weird in kernel
You can try a DDR over clock kernel that you will find in the first page of this thread.
isnt it possible to switch to stock kernel? or something ?:/ because it feels like: the rom gives in one hand and take in the other.
its not easy to fix it?
i dint understand thay with a great hardware like this has, why it is hard to have a rom which is really good. No offense to custom roms, rather to official. And its like a year old tablet.
It's mainly a pipo's ROM : beta firmware
We have observed that with kitkat we get less fps.
But if you try a DDR over clock you will get smoother interface and for no reason I will get back to jelly bean.
Hopefully pipo will release a new one when 3288 will be ready (not sure!)
But we are m8hd owner the luckiest : no bug with this last version !
Could you help me, with overclock? Guess i should download an overclocking app. ishould overclock ram or cpu? to how much mhz? And wouldnt it cause too much heat or battery drain?
Thank very much!
Originally posted by petyaaa6 View PostHehe, well i hope they dont forget the m8hd :/
Thank very much!
So here : http://www.freaktab.com/showthread.p...l=1#post201997 you will find the overclocked kernel.
These kernels have also been undervolted, so battery drains will normaly not happened.
Use the same Tools you use for flashing the rom. But you will unchecked all files except kernel.
Then change the kernel by browsing the overclocked kernel.
If your tablet doesn't boot, reflash with another one.
Try in this order :
kernel_cpu1704h_gpu600_ddr720.img
if OK : try kernel_cpu1704hmin_gpu600_ddr720.img (the best one, overclocked and more undervolted)
if not try kernel_cpu1704h_gpu600_ddr667.img
and so on.
Try in this order :
and so on.
Thanks!
There are currently 1810 users online. 1 members and 1809 guests.
