Beelink S82 / Tronsmart S89 / VissonTech S82 Linux
    Originally posted by stane1983 View Post
    Beelink MXIII (or MX3) 2gb is supported too. I will publish M8 square update as soon as I finish it. Same with others... Just be patient, one by one, today all will be updated, with some new devices added too.
    Stane why is all linux kernels heat up the box units hotter than android os?
    Bugs are Sons of Glitches!
    JustMe
      Just a quick though. Would it be possible for future releases to have a bigger system partition for xbmc? My thumbnail folder is almost 1gb large and I had to move it to /home/ to not fill up the xbmc partition.
      Am I wrong with the assumption that all supported devices got at least 8 gb?
      I would love to have a 4gb system partition if it is possible :-)
        Repartitioning nand leads to flashing with usb burning tool which is currently not supported by my linux build system. Maybe in future.
        If you find my work useful, buy me a beer
        Homepage: http://www.stane1983.com
          Max freq is set to 1.8 Ghz. That can be changed by editing /etc/init.d/S10setup
            Re: Beelink S82 / Tronsmart S89 / VissonTech S82 Linux
            Okay didn't know that. I like the SD card flash so keep the nand the way it is :-P Changing the thumbnail location works for me :-) I'm really happy with your Rom because it got everything I need and there are no random reboots anymore.
            I still hope you will make a kodi version when a stable release is out. The new kodec would save us a lot space on the hdd ;-)
            Thanks for the fast reply and the support. :-)
              Is there any difference between AMLinux and OpenElec which could be found here: http://www.freaktab.com/showthread.p...ased-TV-boxes?
                The only deference for me was that I couldnt get a picture other than openelec logo on my s82
                Proud xbmp>xbmc>kodi user since early days of 1st gen xbox
                XBMC on :
                Tronsmart S89 Quad Core - Openelec
                Atv1 + Crystall HD - Crystalbuntu
                Raspberry Pi - Openelec
                Xios DS - Linux the-hydra
                1st gen xbox, JB Atv2, Ouya, ...
                  how to center the skreen looks like 100 i need 92 %
                    Settings -> System -> Video -> Screen calibration
                      OK i just finis some test xbmc is superb but still some bugs ,used memory goes to 30%from 5 % to 30% i dont know why ?
                        How to Configure TVHeadend?11
                        Hi Stane
                        i'm a total newbie with Linux…installed your Amlinux…..what does this means..
                        • SSH daemon and SFTP server (username: root, password: letmein) ? where to configure that in the settings?
                        in how to configure the settings in the TV Headend Client…..Hostname/Ipadress…127.0.0.1
                        Username root
                        password letmein ???
                        I got error messages…no connection…any advice would be much appreciated...
                        sorry i'm a total newbie
                        thanks
                        Thorsten
                          Isn't that for the square m8, not the round
                            there are some other works on openelec for s82 in here :
                            XBMC on :
                              Originally posted by Groovetemple View Post
                              Hi Stane
                              Username root
                              thanks
                              Thorsten
                              1/ Download a SSH client like PUTTY on your PC
                              2/ Launch PUTTY and insert AMLinux IP device (see in system XBMC)
                              3/ You can see a terminal window.... enter root login, and letmein password
                              4/ your are in system... you can enter reboot command, and many others
                                Is there any way to use other remotes than the original one? I have a harmony remote and thought it would maybe be easier with AMLinux than Android to use other remotes. That would make the use of xbmc much more comfortable.
