"Adjust display refresh rate to match video" is the main difference between linux and android version. If it's completely unnecessary why to stay with linux version?
Beelink S82 / Tronsmart S89 / VissonTech S82 Linux
I believe jeffrey named options wrong. Adjust display refresh rate to match video sets output refresh rate on playback to match video fps. Other option 'converts' video based on video or audio track to match current HDMI output frequency (24, 50 or 60 hz).
Is stuttering somehow connected with video output resolution (I'm on 1080p/60Hz at the moment)?
sorry for the confusion, what i meant to say was that the option "adjust display refresh rare to match video" is the best option. This actually sets your tv in the same refreshrate as the video is. So the video or audio itself doesnt need to be tempered with. With only this on (on linux because on android this doesnt work) you will have a perfectly synced video and tvdisplay without skipping.
The option sync playback to display alters the way the video (which is for example 24Hz) is played back triying to get it inline with the refreshrate the video is set to (for example 60Hz). This will drop video or audio frames to try and match the 60Hz eventhough your video is maybe 24Hz. Depending on which option you choose to drop.
Originally posted by jeffreydeleeuw View Postsorry for the confusion, what i meant to say was that the option "adjust display refresh rare to match video" is the best option. This actually sets your tv in the same refreshrate as the video is. So the video or audio itself doesnt need to be tempered with. With only this on (on linux because on android this doesnt work) you will have a perfectly synced video and tvdisplay without skipping.
I have the same option on (the rest is off) but still experiencing SD stuttering (every 5th seconds). Maybe it's related with my NAS (I'll try the same movie from external USB HDD)
Originally posted by dankec View PostI have the same option on (the rest is off) but still experiencing SD stuttering (every 5th seconds). Maybe it's related with my NAS (I'll try the same movie from external USB HDD)
and do you actually see a change in refreshrate of your tv ? I do see it change on my Samsung
I'm using HDMI and I can see refreshrate changes on my TV.
But it seems that I actually succeed to solve the problem:
I turned off "Allow hardware acceleration (amcodec)" and still leave on "Decoding method: Hardware accelerated" and now there's no problem with SD movies (stuttering stopped)!
Still didn't test this configuration with HD...
So, it seems that turning off amcodec solve the problem here... Anyone with similar experience?
Originally posted by dankec View PostI'm using HDMI and I can see refreshrate changes on my TV.
Bear in mind that we are still waiting for the new amcodec libraries implemented in a new firmware that plays back properly xvid files, maybe in the new SDK that was published recently.
Originally posted by vprasinos View PostYeap, lots of people having problems with XviD stuttering (SD or HD). Your stuttering did not come from the TV's refresh rate but from bad playback of xvid files due to problematic (still) amcodec libraries. What you've just made is deselect all hardware acceleration and use the CPU entirely to do the decoding (hence software decoding).
Thanks for your explanation, let's hope a new version of this great fw will appear together with new bug free amcodec libraries.
Originally posted by dankec View PostThanks for your explanation, let's hope a new version of this great fw will appear together with new bug free amcodec libraries.
Edit:
Forgot to say, I'm still testing and debugging Linux build based on latest kernel, xbmc 13.2 and armhf compiled.
Originally posted by stane1983 View PostMain problem is that amlogic is using very old ffmpeg (amffmpeg) and pretty much customized with random patches not following any official ffmpeg repositories... lot of their own changes.... In latest Android sdk (2014-08-23) amffmpeg is still version 0.8 and they try to implement hevc decoding with it... I can't confirm if working or not because I still don't have s805 device, should have one soon.
Edit:
There are currently 6214 users online. 3 members and 6211 guests.
