Beelink S82 / Tronsmart S89 / VissonTech S82 Linux
Re: Beelink S82 / Tronsmart S89 / VissonTech S82 Linux
Originally posted by stane1983 View Post
Originally posted by newflemmli View PostSadly this build doesn't recognize my FatEx 3 TB device. I get the message "successfully mounted" but can't navigate to the source or it just freezes.
How can I connect to the Internet via WIFI?
I dont have 3tb hdd, but will try to investigate. About wifi, you have wifi managaer under program addons.
Since buying my s82 I think I only used it for 2 weeks before boxing it back up due to insufficient media player capabilities such as auto refresh rate switching and decent quality hardware GPU decoding. Stane1983 has re-ignited my faith in being able to use this box for what I originally needed it for but it really saddens me that he isn't getting full support from the manufacturer... a donated development box - to work with for the benefit of the end user.
People don't forget there are new sources 0108 from amlogic and these are not fully ready yet.
as they same Rome was not built in a day or the matter of fact 2 weeks
hang in there and give some credit to the devs as for them you would not even have half working box and just a door stopper selfish people.
And for the people that cannot wait well what can i say there are plenty of rom abouts now and source so maybe good time to learn rom developing or even reverse engineering and let us hassle you guys for a rom
JustMeBugs are Sons of Glitches!
JustMe
JustMe
Amazing job
Thanks a lot, I was on the verge of giving my box to my Mom, happy didnt do that
it works flawless with no visible issues.
most important it sync the video to display
there are some settings missing hopefully we get them in later builds
a) settings > system > video output:
1- vertical blank sync
2- test patterns
b) settings > system > audio output:
1- audio output device
2- output configuration
3- Number of channels
4- Limit sampling rate
c) settings > system > input devices :
1- Remote control sends keyboard presses
d) settings > system > power saving :
1- Put display to sleep when idle
No rush man , you are simply amazing ...Proud xbmp>xbmc>kodi user since early days of 1st gen xbox
XBMC on :
Tronsmart S89 Quad Core - Openelec
Atv1 + Crystall HD - Crystalbuntu
Raspberry Pi - Openelec
Xios DS - Linux the-hydra
1st gen xbox, JB Atv2, Ouya, ...
Hi all,
I'm also considering buying a device with a amlogic s802. The idea of running linux and xbmc on it is great.
I see there has been some complaints going around for newer hardware versions not running the amlinux stable.
Is this only beelink s82 related? or is it just the same with the tronsmart s89 or vissontech devices?
I know it might be a hard question to answer since these devices are probably all rebranded products.
Greetz
Kweker
Originally posted by Nowandlayda View Posthttp://www.stane1983.com is his website with all the downloads and donation info.
A repo could be browsed to see whats available for those of us who dont have an S802 box yet!
Originally posted by Methanoid View PostThanks but thats NOT a repo.. a Repo would be full of the various compiled ARM Linux apps that you can install to add to the base install. What you provided was a website
there is no repository of any kind. AMLinux is basically pure linux kernel + buildroot as rootfs + amlogic specific stuff and patches. It is not full feature linux distribution.
There are currently 6257 users online. 3 members and 6254 guests.
