Beelink S82 / Tronsmart S89 / VissonTech S82 Linux
    Please upload screenshots of menus fps resolution etc I believe its in in system info
      stane1983,
      Here you go: http://pastebin.com/K4QzNcne
      If you need anything else, just ask.
        simply fantastic work.
        Everybody knows android xbmc cannot compare in any shape or form to linux xbmc.
        Great work!!
        Its a shame my s89 is totally dead (no power), i would of loved to test this.
        Does anyone have fuses diagrams for the s89?
          Screenshots:
ID:	434200Click image for larger version
ID:	434201Click image for larger version
ID:	434202Click image for larger version
ID:	434203Click image for larger version
ID:	434204Click image for larger version
ID:	434205Click image for larger version
ID:	434206Click image for larger version
ID:	434207Click image for larger version
          If you find my work useful, buy me a beer
          Homepage: http://www.stane1983.com
            Originally posted by pyn View Post
            stane1983,
            According to log, wifi driver loaded fine. Maybe Oman will have something to add, I don't have box with ap6210, only 6330 here so can't really debug...
              I love it! I would love it even more if you could create a dual boot with both of your roms!
              @µ$ł!Ω
                Take it easy.... No dualboot for now... It is possible, but little complicated to do. What I'm going to do is finish what I started, fix existing issues, add some more things (that goes to Beelink S82 and M8 boards, both will be updated soon).
                Tvheadend added, dvb drivers and firmwares added, some more surprises will be added...
                  Your the man! Take your time and keep up the excellent work with both of your roms that you cranked out and updated in under a week. Then get to dual bootin haha
                  @µ$ł!Ω
                    very, very nice work stane1983!
                    I only have three items on my wishlist for this *nix build please:
                    1 - ProjectM (or similar) music visualisation plugin to work in full screen 1080p (if it doesn't already, I haven't tried installing yet sorry).
                    2 - LibRetro support so I can play my retro games as well (using bluetooth joysticks).
                    3 - NZB client support for downloads.
                    thank you once again for your great work.
                      I tested my box with ap6210,it works.
                      Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
                        Transmart S89
                        Your download link says 20140719 - AMLinux but the downloading file is 20130719 ?? just a number mistake?
                          Yeah it's just a typo
                          Sent from my LG-D802 using Tapatalk
                            What happens if we want to revert back to Android OS ? Can we still do that via the recovery menu ??
                              Re: Beelink S82 / Tronsmart S89 / VissonTech S82 Linux
                              Yes, just extract android fw to sdcard and power the box with reset button pressed. Next release will have option in xbmc to reboot into recovery
                                Thank you very much for your reply
