Beelink S82 / Tronsmart S89 / VissonTech S82 Linux
    Originally posted by stane1983 View Post
    Guys, Amlogic finally released armhf libraries. Stay tuned, update will be asap...
    RK3288 Devices
    - Overview BOX (LINK !)
      Full linux is just around the corner!
        Nice one
          AW: Beelink S82 / Tronsmart S89 / VissonTech S82 Linux
          Good to hear!
          Don't forget to include the new XBMC Final and the tvheadend backend
            Yessss!!!!
              Stane,
              nice to hear that.
              When you build a full Linux, it is possible that we update XBMC or kodi independently?
              Or will that be a Problem?
              brgds
                Need Help.
                I have a seiki 50",Tronsmart vega s89h, 108k4 Rom(Thx Bob) and trying to play video in xmbc 13.2 on hdmi.I get sound but no video at any resolution?
                  Hey Spike,
                  i think u're in the wrong thread.
                  here it is all about the linux build from stane not android...
                    Sorry,didn't know this was the wrong place,not sure where to go?
                      sub-forum is ok, but not this thread, because it's about LINUX and not Android...
                      RK3288 Devices
                        Stane has been a busy boy. http://www.cnx-software.com/2014/09/...s802-released/
                        @ยต$ł!Ω
                          Awesome, well done stane 👍
                          Proud xbmp>xbmc>kodi user since early days of 1st gen xbox
                          XBMC on :
                          Tronsmart S89 Quad Core - Openelec
                          Atv1 + Crystall HD - Crystalbuntu
                          Raspberry Pi - Openelec
                          Xios DS - Linux the-hydra
                          1st gen xbox, JB Atv2, Ouya, ...
                            Waits on updated Linux firmware 😇
                            Sent from my Amazon Tate using Tapatalk
                              I have M82B box and I'm using Stane's linux XBMC firmware. I'm experiencing some kind of micro-stuttering, mostly on HD movies - constant stuttering, but also on SD - every 5th or 10th seconds a stutter occurs, the rest is smooth, so my question to linux fw users is:
                              - How to set "Adjust display refresh rate to match video" and "Sync playback to display" to have the best experience during playback? Maybe there's another option which makes playing un-smooth? (hw acceleration to soft maybe?)
                              I'm also quite sure that it didn't happend before (maybe my internal box partition (16gb) is full?)
                                sync playback to display should be the only thing to use,mbecause that Will send signal to your tv to match the refreshrate of the movie. The other option alters the video and you definatly dont want that.
