Chuwi VX8 RileyROM 1.1
Originally posted by paiktaras View PostHi,
Is there any way to root this tablet with the last rom (20141210.114520 ) ?
By the way, in this firmware it's not necessary to swap internal memory and microSD modifying boot.img file. Just select "SD card" as preferred storage in Settings. It works :-)
Also, in this firmware there are no EBR files, so I don't know how to resize internal memory for apps :-(
Any idea?Last edited by Koryand'R; 28 January 2015, 17:48.
Originally posted by Koryand'R View PostHi, I'm in 20141212 (the one for D series) and I've rooted using iRoot (you have to install SuperSU and remove chinese crap after that).
Any idea?
Also rriley,can u please help us with rooting this rom?
I don't know if it will work with other series. I've tried to flash "old" firmwares in my Chuwi and the tool doesn't allow to flash because it doesn't match something.
Also keep in mind that in this firmware there is no EBR file, so I don't know how to resize the internal memory for apps :-(
And there are more firmwares in this russian forum :-)Last edited by Koryand'R; 29 January 2015, 20:15.
Originally posted by Koryand'R View PostHere you are but be carefull, it is for D series.
Originally posted by paiktaras View PostWith new firmware I have big battery drain, I am in TO flight mode.....
Any solution?
To the Greek forum "myphone" one user say it's because not enter sleep mode almost never.
Have you found yourself?
If 20141212 firmware, I'm getting 84% deep sleep.
There are currently 1926 users online. 2 members and 1924 guests.
