Chuwi VX8 RileyROM 1.1
ROOT success!!!
Hi again
I did it finally!! I managed to root the Chuwi VX8 MTK8127 with the latest Vroot version!!!VRoot_1.7.9.9730_Setup.exe...use the chinese not the english version.
Later you can replace the Vroot admin App, with SuperSU, ...just from Play Store and uninstalling all the chines app you don't need ( I used Root Unisntalller), beware not to install "DeviceTest_MTK.apk" an App with a Blue Wrench Icon, I don't know whether it's needed or nor by the OS, so just leave it for your own sake.
If are having problem replacing Vroot with SuperSU, just follow this link .
Now I'm begining to feel very happy with this Chuwi...
I recommend staying on Dalvik. There are some compatibility issues running apps in ART.
You can try ART and see if you have problems with apps disappearing from your tablet. The problem is that some apps aren't designed to run in ART and won't show up in the app drawer.Randy
Originally posted by rrileypm View PostI recommend staying on Dalvik. There are some compatibility issues running apps in ART.
BTW,i still wait for CWM(and no new rom?)
Someone a lot smarter than me will have to come up with a CWM. I can't get any of my tools/scripts to work with this stock recovery....it fails every time. I couldn't even do it manually.
If anyone runs across an update stock firmware from Chuwi, send me a link and I will make a new ROM.Randy
Originally posted by rrileypm View PostSomeone a lot smarter than me will have to come up with a CWM. I can't get any of my tools/scripts to work with this stock recovery....it fails every time. I couldn't even do it manually.
Meanwile i will stick with your great rom
If i'll have news about a newer rom i will post here(me or another one who have this tablet?)
Thanks a lot for the nice work.
There are currently 1913 users online. 0 members and 1913 guests.
