R89-Multimedia playback and XBMC feedback here
I just flashed Wasser 2.0.2 to my new r89 2/16gb.
I can't get wasser kodi to start, once it get past the first start screen saying it's setting up, it goes to a blank black screen then close to desktop after a few seconds.
Tried to play video with mx player, and got the sound to finally play, but in 2 channel. Some other format won't play sound at all.
My receiver is able to take most known format, so my guess is the R89 sending only 2.0 sound. (Sony STR-DA6400ES) I connected the R89 directly to the amp by HDMI.
Reading directly on lan (I just realized my old N wifi isn't enough to feed movie on this box, so I'm going cat6 hardwire atm while I fix everything then I'll change my router for a decend AC one)
What am I doing wrong ?
Should I tried to reflash Wasser even if it seems to be ok?
Try finless?
Stock was working better atm, so I'll take any suggestions.
Thanks!
I just installed SPMC and it does the same thing as kodi : Install, show a first load screen, goes blank 15-20 sec, shows normal load screen 2 sec and then close to desktop. Any further attempt to load it shows the load screen 2 sec before closing with no error warning.
Originally posted by mo123 View PostIf you are using such an old ROM, you are going to have issues.
110k4 is the latest ROM.
Half ready garbage
Unfortunately i bought this Beelink R89 2/16 Gb garbage. After a month i droped out, beacuse this this garbage cant play any multichannel video with DD/DTS sound without problems. This garbage can play low quality divx video with PCM stereo sound only. If you have a home cinema system, with multichannel receiver dont buy this cheap garbage.
This box has several mistakes. Micro freezes, micro-stutters, Kodi incompatibility. etc.
This is a half ready garbage without software support.
The most first important feature, to play multichannel movies does not work.
I use my 5 years old WD TV Hd player again to play movies.
This is shame.
DONT BUY THIS GARBAGE!!!!
Originally posted by Loutra2015 View PostUnfortunately i bought this Beelink R89 2/16 Gb garbage. After a month i droped out, beacuse this this garbage cant play any multichannel video with DD/DTS sound without problems. This garbage can play low quality divx video with PCM stereo sound only. If you have a home cinema system, with multichannel receiver dont buy this cheap garbage.
This is shame.
Audio xbmc support : 1. add the judgment for null pointer when hardware write
2. optimize logic when xbmc open the audio output stream
hardware/alsa_sound/AudioHardwareALSA.cpp | 9 ++-------
hardware/alsa_sound/AudioStreamOutALSA.cpp | 16 +++++++++-------
hardware/alsa_sound/alsa_default.cpp | 15 +++++++--------
3 files changed, 18 insertions(+), 22 deletions(-)Audio : add the support for XBMC passthrough---
frameworks/av/media/libmedia/AudioTrack.cpp | 7 +++++
hardware/alsa_sound/AudioHardwareALSA.cpp | 41 ++++++++++++++++++++-----
hardware/alsa_sound/AudioHardwareALSA.h | 1 +
hardware/alsa_sound/AudioStreamOutALSA.cpp | 44 ++++++++++++++++++++-------
hardware/alsa_sound/alsa_default.cpp | 19 +++++-------
system/core/init/property_service.c | 9 +++++-
6 files changed, 90 insertions(+), 31 deletions(-)Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
agree
Originally posted by Laethageal View PostWell I wish kodi will work with 111k4.
But at least, they are trying to fix what's wrong. Bwtter then some other out there 😊
i agree with you i use to think minix was a good brand thinking they had a big team of employees working on F/W issues but then i saw a review made by cnx on the minix 8-h and i was shocked i think beelink will be a better manufacturer then minix and others because they are more involved.
Originally posted by ademturk View Posti agree with you i use to think minix was a good brand thinking they had a big team of employees working on F/W issues but then i saw a review made by cnx on the minix 8-h and i was shocked i think beelink will be a better manufacturer then minix and others because they are more involved.
Originally posted by Tarwin View PostSo I updated to firmware 111K and now in the stock Kodi there is no choice for the number of channels (though it does give me the choice to upmix).
Is anyone else experiencing this? Is it just not detecting my receiver properly? The choice was present in 110K
Originally posted by 4WheelSpyder View PostI have always left that setting at 2 channels and still got 5.1
I also noticed there is no option to change the screen format to stretch 16:9 etc when in playback.
These are normally present in normal kodi version.
I also have no option for speaker quantity setup eg. 5.1 but I still get pass through Dts and Dolby digital fine so no biggy there.
I guess there are options missing from modification.
Originally posted by Jakemate View PostI also noticed there is no option to change the screen format to stretch 16:9 etc when in playback.
Sent from my iPhone using TapatalkEasy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
There are currently 2003 users online. 4 members and 1999 guests.
