R89-Multimedia playback and XBMC feedback here
    Main Menu Icon "XBMC" doesn't work right after update
    Hello,
    i have got my new Beelink R89 and i'm very happy about it. I use 110k... Version as Original. When i startet xbmc from the desktop, it told me to update the 14 alpha version. So i downloaded the newest beta from the web, deinstalled the old app and installed the new one.
    Now i need some help from experienced users here.
    1)
    From now after reboot the big icon xbmc on the desktop has no more function and i have to start with another icon i added to favorites.
    How can i get the big icon working in the upper middle?
    2)
    Fast fowarding in movies crashes the app to desktop when streaming with gigabit in smb mode.
    3)
    Is it possible to get a QWERTZ - German keyboard version in xmbc, perhaps with äöü?
    4)
    I have the same micro-freezes as bloodgnome described them some postst before.
    I'm new in this materie and i would be happy if i could get some help.
    Greetings
    Michael
    Beelink R89 2/16GB Version PCB 3.0, Stock Firmware 111K4110_1219, SPMC 14.1
    Input: Wireless Logitech K340 Keyboard & M505 Mouse, Output: Philips 42PFL7404H/12
      1) I think maybe because at the past the name (directory) was xxx.xbmc.yyy and now xxx.kodi.yyy so the launcher isn't able to find the application (but not sure about this, because I don't use this launcher and not sure about the old name before the update)
      about 2-3) sorry no idea because use english also qwerty
      and 4) micro-freezes maybe because of the update? Or also before the update?
      RK3288 Devices
      - Overview BOX (LINK !)
        Looks like the auto frame rate switcher script from minix forum has been modded and tested on rk3288. Read 3rd post here https://www.minixforum.com/threads/a...bmc.601/page-7
        Here is Mafarricos hub
        Modded Addons from Mafarricos. Contribute to Mafarricos/Mafarricos-modded-xbmc-addons development by creating an account on GitHub.
        The funniest thing about this particular signature of mine is that by the time you realize it doesn't say anything it's to late to stop reading it
          PS I'm out of town and can't test this script until Monday. If someone could test it and post results that would be great.
            If someone want's to test it, you have to take this
            but I don't know if it will also work at rk3288 because I can't identity if he talk about JB or the 'KK' port at rk3188 ore a 'real' KK at rk3288...
            Code:
            v1.3.5
              root check fix
            v1.3.4
              permissions fix (ty enen92)
            v1.3.3
              ro.product.name has to identify 720p or 1080p kernel.
              on 720p kernel 24hz works as 1080p24Hz
            EDIT
            He use the correct path '/sys/class/display/display0.HDMI/mode' BUT instead of removing this stupid device check (like the guy at the amlogic sub-forum had done) he only replaced the MINIX with 'SAMSUNG rk3188'
            RK3288 Devices
              He posted this.....`Already confirmed that this addon can work in a rockchip based box, I know is a bit offtopic. But this addon should be divulged also in a generic android/xbmc forum` that was on Nov 7 so I assume 3288 kk . I have no box to test it on right now cause I'm not at home. test it bro.
                No, not really OT, but because of this http://www.freaktab.com/showthread.p...l=1#post237918 (only gives 50/60 Hz but not the also supported 24/25/30 (maybe an issues at the EDID(-protocol)?)) I didn't have a deeper look at it, because at this situation at my environment for me it's senseless and I cannot test it...
                See my EDIT and you will find out it couldn't work at our devices...
                BTW: rk3188 isn't rk3288
                RK3288 Devices
                  I know 3188 isn't 3288 lol. I ask u because i know u have 3188 device
                    Yes, but have the same 'fps missing problem' (24/25/30) at it running the fake KK (seems to be rockchip related but I'm not sure if I also only had have 50/60 at JB)
                    I think my SAT receiver isn't interesting in EDID and I have no idea how Amlogic handle it...
                    RK3288 Devices
                      Here you can find the 'cleaned' version http://www.freaktab.com/showthread.p...r-Amlogic-S802
                      If I remember correctly you only have to replace
                      Code:
                      /sys/class/display/mode
                      with
                      Code:
                      at the 'fswitch_util.py'
                      and to be sure that at '/sys/class/display/display0.HDMI/mode' exists the correct rights (-rw-rw-rw-) which I think exists by default....
                      RK3288 Devices
                        How to install use this addon It's Version 1.3.6 for all RK's. I have downloaded it here, but ist is no apk file. Its I don't know what to do and i have micro freezes...
                          BTW: meanwhile there exists a 1.3.6b
                          Here you find the installation instructions at XBMC:
                          Here mo123 describe which settings at XBMC you have to do
                          RK3288 Devices
                            FYI
                            Have you saw this
                            Frequency switcher v1.3.6b now work on all RK3288 devices
                            RK3288 Devices
                              http://www.freaktab.com/showthread.p...l=1#post251805
                              Thank you for the hint. I've got it installed. But now when i try to configure, it says that my "google manta" is not supported. Which version of XBMC should i use? Actually i use Finless ROM 1.2.
                                Won't work on Finless ROM, since it spoofs device as Google Manta and not Rockchip rk3288 device.
                                You can edit your build.prop file or install another ROM.
