R89-Multimedia playback and XBMC feedback here
XBMC.apk
hey boys and girls try this xbmc.apk its the one from ugoos ut3 http://www.mediafire.com/download/y7...rk3288-265.apk
and this is the skype app that worked for me none of the r89 F/W let me sign into skype https://www.mediafire.com/?kz0i8dro5f2e2etLast edited by ademturk; 10-02-2014, 17:11.
Originally posted by ademturk View Posthey boys and girls try this xbmc.apk its the one from ugoos ut3 https://www.mediafire.com/?kz0i8dro5f2e2et
What is special about that XBMC? All the XBMC versions I have tried work well, except can't passthrough Dolby Digital and DTS.
Also, Skype works on my R89, what problems did you have with your Skype?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
and this is the skype app that worked for me none of the r89 F/W let me sign into skype https://www.mediafire.com/?kz0i8dro5f2e2etR-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
xbmc
Originally posted by clarkss12 View PostWhat is special about that XBMC? All the XBMC versions I have tried work well, except can't passthrough Dolby Digital and DTS.
well 107k4 and 108k4 f/w i had problems playing video with xbmc every 10 seconds or so the video would freez for a second also with with mx player and on both f/w's i could not sign in to skype on the 108k4 f/w both the video playback and mouse would freez every 10 seconds or so
xbmc
Originally posted by bluesmanuk View PostTried this XBMC mod a few days ago and for most usage, it's just not that good.
i actually copied this one right out of the ugoos ut3 and it actually works really good with video play back from my nas device although i have not tested a verity of videos
It's the 13.0 Alpha 12 with h.265 hardware acceleration by rockchip...
=> my experience:
Originally posted by no_spam_for_me View PostRK3288 Devices
- Overview BOX (LINK !)
Tried both Gotham 13.2 and Kodi. If I select Spdif surround sound gets to the AV receiver even without passthrough selected. Selecting passthrough provides a fuller sound but the video would jump every 2 seconds. Tried a few XBMC settings but no luck so far.
Update. It is when the transcoding option is enabled with passthrough that the video would jump every 2 seconds. Disabling the transcoding solved the problem but does not provide as full a sound.
Edit: Correction to the above. The settings on my AV receiver was changed without me noticing it. After resetting it to "straight" there is no surround sound to the AV receiver without passthrough selected.Last edited by 4WheelSpyder; 10-05-2014, 22:38.
Just tried SPMC to see if the choppy video when audio transcoding is enabled would be better. When transcoding is selected in SPMC all that comes through is the digital noise (like playing digital sound over an analogue system). The choppy video is almost as if some video processing time is "hijacked" to perform the transcoding.
video playback compare
hardware playback artifacts
more info https://translate.google.com/transla...ubox-r89-obzor
Had some spare cycles this PM to do some comparisons between the Tronsmart Vega running Finless 1.9 Rom and the U-box R89 109k4 with the HDMI patch, both running Kodi 14.0.
In none of my tests did the Vega create the choppy video that the U-Box did. Enabling the passthrough on the Vega without enabling transcoding would result in surround sound for all but AAC 5.1 audio. This aligns with the tests on the U-Box running the stock video player and is probably a limitation of the RX-V671. Enabling the transcoding on the Vega would create surround sound for all 5.1 audio formats I could throw at it, while providing a smooth video. I therefore believe there is potentially problem with the U-Box passthrough/ HDMI video sharing of resources.
Originally posted by ademturk View Postwell 107k4 and 108k4 f/w i had problems playing video with xbmc every 10 seconds or so the video would freez for a second also with with mx player and on both f/w's i could not sign in to skype on the 108k4 f/w both the video playback and mouse would freez every 10 seconds or so
There are currently 2620 users online. 5 members and 2615 guests.
