Pipo P4 RileyROM 1.7
    This ROM is based on official Pipo firmware dated 9/9/14 (wifi) and 9/10/14 (3G). More changes in the charging system...and hopefully a fix to the Facebook bug.
    I'm still having trouble deodexing the framework.jar file to invoke the multi-user support...as soon as I do, I will post an update.
    This ROM has all of the usual RileyROM features:
    Rooted with SuperSU
    Deboated
    Init.d/Busybox support added
    Pre-Install added (can install apps automatically from external SD "autoinstall" folder)
    Reboot App by Petrus
    2, 4, 6, 8, 10 or 12gb user app space (by choosing the desired parameter file).
    This time we have both wifi and 3G versions.
    Download Wifi Version
    Download
    3G Version
    Abdul_pt has provided us with a TWRP recovery for the P4. I've included it in the ROM kit this time, but if you want to download it...here it is:
    Download
    I recommend that you flash the stock recovery first to allow proper formatting of the partitions. Then flash TWRP Recovery by itself.
    Just uncheck everything except the recovery line in the flash tool, browse to where you've downloaded this file, and flash it by itself. No need in erasing IDB.
    Enjoy!!!!!!
    If this ROM makes a positive difference for your tablet, please consider a donation to support further RileyROM development. Just click the donate button in my signature.
    Randy
    Thanks Randy, i will let you know the outcome tonight
      Rooted with SuperSU
      Deboated
      Download
      3G Version
      Download
      Enjoy!!!!!!
      sorry riley but im getting 077_rk3288-3.10-unboot.parameter6 is not existed, stop running
        and im in some sort of brick mode now..... help is needed
          What did you do?
            ok.... now out of the brick.... not panicked just learning....lol
              im trying to install new rom 117..... but something is not right ?
                "Something"? If you can explain a little bit more what the problem is maybe someone can help you.
                  lol.... sorry.... this .."riley but im getting 077_rk3288-3.10-unboot.parameter6 is not existed, stop running"
                    What i did with 1.6, i just navigated from android tool and that line, to the right file in the rileyrom folder. I will try in 8 hours when i'm home so then i can let you know if i can make it work.
                      cool
                        Installing now!
                          I also got the same message....
                            Originally posted by locutus2000 View Post
                            Installing now!
                            And is it working correctly?
                              OK, guys...there's an easy fix to the flashing problem.
                              Open the flash tool and click the browse button to the right of the parameter line. Browse to the RileyROM folder and choose which parameterXX.txt file you want to use. The file name has just changed in the parameter files for this firmware, that's all. Once you get the proper parameter file set you can flash the ROM as usual.
                              Randy
