holding volume up and power boots you into the english recovery
Rooting a Nextbook NX700QC16G?!?!?!?
Originally posted by Bullfrog View PostMetalbeck, does your downloads work with Windows 8? I have 8 and used your downloads but still had issues, however not the same issue it just didn't do anything this time, no error message now download, nothing. Wasn't sure if it was because of Windows 8 or not, I know there are different directions for 7 vs 8 and different download maybe?
Edit* Apparently you are not alone having issues doing the firmware upgrade when using a Win 8 machine, and a great tutorial on how to get it to work was posted at http://nextbook7.blogspot.com/2014/1...qc16g-usb.html however I still recommend using a Win 7 machine as it appears some people are still having issues getting the drivers to install.
Originally posted by corruption View PostThese guys have successfully got cmw working on an rca tablet with the same board! So I'm optimistic that we could be next..
I think I've got TWRP working on my RCA with MT8127, but I haven't worked on it in awhile... was in the middle of testing it and trying to compile a custom ROM from source.
Rooting should be easy using either Kingo Root (Pre KitKat) or vRoot or iRoot (KitKat and possibly Lollipop).
ShaunMTFreaktab Rom Developer
The RCA tablet is almost the same as my DL701Q, both use ubifs filesytem. My recovery is here. http://forum.xda-developers.com/andr...mware-t3046756 Neither recovery will work on Nextbook as is, cause Nextbook uses ext4, (well my recovery might cause it's a dual recovery, requires adb commands to switch to ext4 recovery, not recommended) You guys need to just port or build a ext4 recovery, not that hard, much easier than ubifs filesystems.
If I had the tablet I would build a recovery for it, but I don't work on devices I don't have.
After you all get your custom recovery you use recovery to flash http://download.chainfire.eu/696/Sup...erSU-v2.46.zip which will provide root.
Originally posted by vampirefo View PostThe RCA tablet is almost the same as my DL701Q, both use ubifs filesytem. My recovery is here. http://forum.xda-developers.com/andr...mware-t3046756 Neither recovery will work on Nextbook as is, cause Nextbook uses ext4, (well my recovery might cause it's a dual recovery, requires adb commands to switch to ext4 recovery, not recommended) You guys need to just port or build a ext4 recovery, not that hard, much easier than ubifs filesystems.
My RCA uses EXT4 on EMMC...
UBIFS is a pain to mess with. UBIFS probably also means MTD NAND instead of EMMC. UBIFS is most often used because MTD NAND doesn't support EXT4 (without custom kernel drivers like RockChip uses).Freaktab Rom Developer
There are currently 5502 users online. 4 members and 5498 guests.
