HPH 4Gb / 32Gb New Firmware Versions from Nagrace
    I get hdmi no signal some time, it's force me to take out the DC power contact and after its fine...
    Report any bugg or inform Tina so we can help each other to make this firmware one of the best
      Anyone have problem with hdmi no signal?
        Maybe the box not get enough of power or something like that?
          If your box is powered by 3A adapter, it should have plenty of power even for the most demanding tasks. On the other hand, I had similar case with my last rk3188 hdmi stick which worked on only one tv but not on any other I tried. It must be some weird incompatibility. Maybe your tv doesn't comply with hdmi specification? Just a guess.
            Hi
            any good and stable kodi or helix for my hph I have spmc but with pvr tvheadend clients it's not so stable
              system update find new firmware 1.4.5 and always crashed on update . Anybody have 1.4.5 firmware?
                Hi here https://mega.co.nz/#!0lFRRJ6J!vXSd9v...0kiHBhtrqRU-0o
                  Hi, the link provided is no longer valid, the file has been deleted.
                  Any news from Nagrace? Did they release anything newer after 1.4.5?
                    There have been several updates since
                    TRN6A_HPH-FO-N6_RK3288_4.4.2_EN_US_FT0_V1.4.6
                    TRN6A_HPH-FO-N6_RK3288_4.4.2_EN_US_FT0_V1.4.7
                    TRN6A_HPH-FO-N6_RK3288_4.4.2_EN_US_FT0_V1.4.8
                    Android5.1.1_u…160125_1715
                    I also released several Lollipop firmwares.
                    If you need any help or want to try a new firmware, you can PM with the exact device you have and your requirements eg. want to use HD Audio, want dual-boot firmware, want a smooth Kodi for video playback etc.
                      Hi Mo,
                      can you provide the link to the latest LP Nagrace firmware for NT-V6 32G ?
                      Thanks!
                        Hi Mo,
                        Thanks!
                        I will upload it.
                        Just need to add Google apps.
                        I will also upload new custom firmware later, just waiting for some patches.
                          need a new build mo... with latest from nagrace im getting a lot of crashing all of a sudden ..... box is playing half a stream then restarting.... even loosing web settings ?
                            Hi
                            Nagrace is hard busy improving the HDMi-IN and other things behind the scenes.
                            I'm waiting for the new HDMI-IN, so I can make a single firmware for all devices.
                            It should also be a very stable firmware & I'll make a dual-boot also.
                            What Kodi are you using and what streams, addons, then I can also test.
                              kodi 16 .... latest 3288 firmware from candy.... 3288 ..... playing anything in kodi causes it.... for instance i was watching 2 tv episodes of new show vinyl yesterday.... on exodus i think..... first played all the way through no pobs.... second crashed about 10 mins in..... box is kept clean with cccleaner.... and ares wizard in kodi.... i was not sure if its kodi or box.... not seen anything about it.... and 2 customers have had same issue..... can crash upto 10 times in a day ?
                                My custom firmware and NTMC 16 should be a lot better, but just waiting for the new firmware to be finished by them before I can work on it.
                                Forgot to ask, are you using the Dec 2015 Kitkat firmware or the Jan 2016 Lollipop one?
                                Lollipop has lots of improvements in video playback that is not possible on Kitkat.
