HPH 4Gb / 32Gb New Firmware Versions from Nagrace
Originally posted by mo123db96618 Android-> Lib: handling noise problems Youku Live
2015-01-27 5fa1502 HphLaucherTv: Use whatismyipaddress.com locate abroad, domestic use Baidu positioning, no longer in use Location Positioning
2015-01-27 50899dc Android-> DeviceTest: KeyTest test Recovery compatible F12 key code values
2015-01-26 205797b Android-> LeHomeAssistant: Roca assistant locale automatically matches the two-dimensional code scanning environment
2015-01-26 b66c5d3 Android-> lehome: Modify settings interface Roca assistant logo
2015-01-20 20b5ac9 Kernel-> NoDeepSleep: do not enter Deep Sleep
2015-01-20 212e4e5 Android-> DLNA: Roca assistant APK confusion
2015-01-19 0c8ff24 Android-> power: add hibernate, reboot
2015-01-16 3d05ed8 Kernel-> gmac: change large parts of the machine rx_delay improve the problem of slow network port
2015-01-16 1b3bf8b Android-> key: instead of using the F12 key MUTE, prevent inexplicable silence
2015-01-16 57bf166 Merge branch 'tchip_back' into tchip
2015-01-15 474ea78 Android-> FileExplorer:. 1 change passwords saved criteria. 2. Modify the null pointer may cause a few places. 3. Modify .gitignore ignore patch file
2015-01-14 aaf39bf Revert "Android-> Google_GMS: Google Update Service"
Guest
Thumb up for NoDeepSleep and Hibernate features
btw, anyone experiencing "Device linked to this TV" toast message?
What does that mean? I don't have any devices that can connect to the box or tv...?
Originally posted by Burs View PostThumb up for NoDeepSleep and Hibernate features
Guest
Originally posted by Shadi86 View PostIs it better without deep sleep? I hope it's sleep good for me though
There are currently 3236 users online. 0 members and 3236 guests.
