Bart
HPH 4Gb / 32Gb New Firmware Versions from Nagrace
New official firmware from Nagrace - 23/12/2014
Download with jdownloader.org and set to less than 4 threads downloading in top menu.
Then baidu will download at an okay speed and not stop or ask for captchas and also not struggle to download it from the website.
Changes are the same as for new Beelink,Ugoos etc. firmware
without custom ROM tweaks.
Should work with passthrough in SPMC.
(Might need to uninstall the included one)Last edited by mo123; 12-26-2014, 16:46.
Originally posted by Shadi86 View PostI tested it with spmc, It's was spmc v13.3.4 already pre installed in the new firmware.
I have test your rom spdif trough xbmc and it's not work so good it's stuttering with noisy sound it's only (spdif side) it not work on your rom...
It will show also 1 second green Android logo before bootanimation if kernel is flashed correctly.
Guest
Originally posted by mo123 View PostNew official firmware from Nagrace - 23/12/2014
Now we're waiting for v1.4 lol
Firmware was downloading between 150-200KBps for me.
Would be nice to know if SPDIF works better with this and also test with my v1.3 kernel and the new firmware.
Then I know it's something Rockchip fixed in the kernel or if it's something in the firmware's system files that is improved.
Maybe next ROM will be Lollipop, just kidding.
Guest
It's problem with wifi, when I go to settings to activate it the wifi it just freeze and after that get message ''setting don't answer ''something and the settings close after that, it's my translation from Swedish, any idea guys can you test active wifi and see what will happen
Edit: it's the latest firmware
There are currently 2958 users online. 3 members and 2955 guests.
