Verifying package, failed to verify whole file signature
HPH 4Gb / 32Gb New Firmware Versions from Nagrace
Originally posted by mo123You have to unzip the zip file on your PC.
Then rename 1.4.1/full_package.zip to update.zip
Then copy it to your SD-Card.
It will detect the update and ask you to install it.
If not detected, you have to restart your device.
Guest
Originally posted by Shadi86 View PostHello everybody
I experience the device restart when I wake it up from standby it's happening sometime. please share with you everything suspect behavior even if it is small and not disturbing behavior it's important so we can report and make this device best of the best
I can confirm the same issue above about blue screen, it's happening to me after the device wake up after sleep, its happen but not often and I forget last when it happened.
I am using mele f10 deluxe remote it's have ir learning and I also controlled my TV with it and my receiver, every time I put my hph nagrace in sleep it's fall back from sleep same second, I try 3 time to set it in sleep, and after few try it's fall on sleep, and this happens sometime, and it's can be sensitive and it can wake it up if I push on random button, it would be great if we only can wake the device only with the power button, I know we have this feature already but maybe more stable.
A new hdmi CEC feature, maybe a easy one like only '' ON and OFF'' , or more advanced CEC control it can maybe be like this way:
MENU
|ON and Off |
|One key play|
|One key power off|
... ETC
And a new and better shutdown menu context, maybe not important because dozens of app on the market.Last edited by Shadi86; 18 January 2015, 12:13.
Is that a New firmware??
OTA_TRN6A_HPH-FO-N6_RK3288_4.4.2_EN_US_FT0_V1.4.3_150112.rar - 1.36G
any change log/release notes?
and what about that one?
BETA_TRN6A_HPH-FO-N6_RK3288_4.4.2_EN_US_FT0_V1.5.3_150116.rar - 439.7M
Guest
Originally posted by oggielerr View PostOTA_TRN6A_HPH-FO-N6_RK3288_4.4.2_EN_US_FT0_V1.4.3_150112.rar - 1.36G
http://pan.baidu.com/s/1ntE8Nn7
I thought OTA was said to be be fully functional starting from latest update, no?
Are these some early betas, so they are not opened to public for everyone?
Originally posted by mo123It's the same as the one released on 07/01/2015
No noticeable differences.
Rockchip also didn't make new changes since then according to the changelog in the zip file.
Still waiting for the home button to get fixed along with some other nice fixes.
I just have the volume go down to zero randomly but thats why I love android. Never a dull momentLast edited by bloatman; 26 January 2015, 03:34.
Guest
Originally posted by bloatman View Postmy home works fine using 07/01/2015, I just have the volume go down to zero randomly but thats why I love android. Never a dull momentI'm banging my head too, because of that funny audio muting. I also had one rk3188 tablet (or better say rom) in the past with similar issue, but it was decreasing volume one notch at a time, and not all the way down like on this box. Today I made a profile in Automagic to restore my audio volume as soon as it drops below my desired one. It almost does it without even seeing it. You can do the same thing with Tasker. This will be a decent workaround for now, until someone make a fix.
Originally posted by Burs View PostlolI'm banging my head too, because of that funny audio muting. I also had one rk3188 tablet (or better say rom) in the past with similar issue, but it was decreasing volume one notch at a time, and not all the way down like on this box. Today I made a profile in Automagic to restore my audio volume as soon as it drops below my desired one. It almost does it without even seeing it. You can do the same thing with Tasker. This will be a decent workaround for now, until someone make a fix.
Guest
Originally posted by bloatman View PostI had the same problem with slowly decreasing sound in a rk3188 rom, forgot which one, there were so many. It became really annoying after a while.
Guest
If anyone's interested in the newest v1.5.3 firmware, it can be downloaded from mediafire here:
http://www.mediafire.com/download/tt9ssppbd4c4sci/BETA_TRN6A_HPH-FO-N6_RK3288_4.4.2_EN_US_FT0_V1.5.3_150116.rar
Thanks Tina.
There are currently 2261 users online. 0 members and 2261 guests.
