Pipo M7pro - Cyanogenmod 11 (Android 4.4.4) porting
    no, do not use cwm install yet.
    You have to use flash.sh from the out/target/.../m7pro directory!
    The zip file cm11 produces does not incorporate the rockchip specific checksums for the img files!
    Have a look at flash.sh to see what it does.
      Finally got Cyanogen on my pipo M7pro
      I have flashed the system.img and boot.img created with ROM_FLASH_TOOLS (from Riley) under windows with a new parameter files that matches yours.
      It runs well, but Wifi can't be activated !
        That's great news.
        I've got a couple of new ROM's to do tonight, but I have my M7 Pro with me if you need a tester...once you start playing with wifi, bluetooth and GPS stuff. I don't have a 3G version, though.
        Randy
          Originally posted by stevejc View Post
          well well well,
          bravo !
          check with fishpepper the wifi thing as I remember he said his build had all working (but gps).
            Did you flash the kernel img? see custom_boot.sh and flash.sh how they pack it.
            If you have a dump of your kernel.img:
            strings kernel.img|grep Linux|head
            should show ...@lzj-desktop in the string
            Regards,
            Simon
              Regards,
              Simon
              Yes
              That was that, my fault, I was thinking that it was the same as before.
              So wifi running with my compilation.
              So now I will test it.
              Last question (not tested yet) the recovey.img created is it working ? or can I use twrp
              Thanks so great job
                Hi all,
                I just updated the github repo. Note that i am testing the Bluetooth fix with that commit,
                so bt will probably fail Do not build it unless you are curious to see how it crashes.
                I will post again when i have something working.
                I removed the manifest file, in order to build against my github repos you have
                to edit .repo/local_manifests/m7pro.xml:
                Code:
                <?xml version="1.0" encoding="UTF-8"?>
                <manifest>
                <project path="device/pipo/m7pro" name="fishpepper/android_device_pipo_m7pro" remote="github" revision="master"/>
                <remove-project name="CyanogenMod/android_packages_apps_Bluetooth" />
                <project path="packages/apps/Bluetooth" name="fishpepper/android_packages_apps_Bluetooth" remote="github" revision="cm-11.0"/>
                </manifest>
                afterwards do a
                repo sync
                This should fetch device/pipo/m7pro from my github repo and should replace the Bluetooth.apk sources with my patched version.
                regards,
                Simon
                  Hi all,
                  Code:
                  <manifest>
                  </manifest>
                  afterwards do a
                  repo sync
                  regards,
                  Simon
                  In mine Bluetooth works but maybe not GPS as you wrote before.
                    Hi!
                    Yes
                    ok, so commit
                    is verified to have wifi working. Good to know someone else could reproduce it!
                    Please let me know any findings. However dont expect it to work, so far i just began with porting.
                    Playing movies is probably broken (missing libs etc).
                    But i am happy to hear any findings, either non working or working comments could help me to fix stuff
                    (if you do an "adb logcat" on a console and put the output to pastebin would also help a lot while doing your tests)
                    Thanks so great job
                    No, i did not put any effort into recovery yet. I hava a generic (?) rk3188 cwm recovery running but i dont use it. the rkflash tool is more convenient for testing.
                      good to see stevejc and fishpepper advancing at a faast pace during the last couple of days.
                      On my side,
                      have prepared another clean linux install on another machine and a dedicated 40GB hdd;
                      for now, waiting for a repo sync with vanilla CM11 tree to end (this time without filling any FS )
                      will keep you informed,
                        On my side,
                        Be careful, My VM is already 60 Go Full !
                        To fishpepper,
                        To help you to debug with more testers, can I provide a link to my compiled ROM ?
                          I would be happy to test it after I get done with two P1 ROM's.
                          Randy
                            yes sure, from my side you can provide a link
                            (write down a note somewhere against which commit it was built)
                            I am still unsure if it is allowed to upload/share a rom with all that binary (non GPL) stuff in it :-\
                              The end product...as long as it works...is OK to publish...giving credits where credits are due. It's the sources that are protected.
                              Randy
                                So here it is Pipo_M7_Pro_Cyanogen11_1.0 : https://mega.co.nz/#!9J1EgbhB!Ypz5cT...8kzGBmkYX51lMI
                                Use ROM_Flash_Tool_137.exe provided in the archive to flash it, Erase NAND first
                                You need to have all lines checked.
                                I use the same parameter as fishpepper so you will get 6.5 Go for App. (only one for the test)
                                The recovery provided is standard one, I have also put TWRP, but you must flash it after it has booted once with only recoveryTWRP.img checked this time.
                                As it's a cyanogen rom, you don't have Google apps in, but you can have zip files here : http://wiki.cyanogenmod.org/w/Google_Apps
                                You flash them with booting in TWRP recovery.
                                This Rom is for testing only, please report any problem found.
                                The commit version is : b9358a0
                                All credits go to fishpepper who gave us a new way to explore on this Pipo M7pro.
                                What I found not working now : (I will add them here after)
                                - Video, with Mx Player, software decoding works but not hardware
                                - Audio : Mp3 files not working (flac files OK), audio through bluetooth
                                for others Models, please wait ...
