Hi, trying to adapt to M8HD, it compiles but for the moment doesn't boot
I think it's due to boot.img format of last ROM of Pipo M8HD.
Stay tune ...
I would suggest you checkout the device_android_m7pro (or fork it on github)
Then fetch the latest rom from pipo and put it in pipo_rom/datecode.zip
then try to run fetch_prebuilts.sh, the last step (copying proprietary files) will probably fail.
Now modify prop...files.txt to match the files you want to copy and also copy pipo_rom/extracted/root/init.rk* ueve*rc over the m7pro ones.
hi all,
on my side,
I had error running fetch_prebuilts.sh :
the make section was not able to install the compiled binaries in /usr/local/bin as I am not root;
so I modified Makefile by adding sudo at the beginning of the 5 install lines
hi all,
on my side,
Strange.. It should not install anything, its just calling make (not make install). The script uses the binaries from the build directory then.
Had to remove and purge openjdk as it is not supported (by the build chain)
So I have installed oracle jdk instead, ( I don't like it, it s bloated , and I had seen that ant wanted openjdk at some point...)
Then , oops,
Got errors during make clean in brunch m7pro,
Seems that some tools in there are for 64bit Linux, and I am in 32bit,
Can anyone confirm please ?
[QUOTE=raxy;243226]
We have never seen any GUI for FM radio in the past on this tablet. If you can make it work, that would be fine but GPS and BT are much more needed.
Hello everyone! Here guys write that GPS is more important than FM radio, but the GPS is working there in other firmwares, but no FM radio nigde.Esli would M7PRO earned FM radio, it would be very great, think that many will be happy!
-We had to move to 64-bit for Gingerbread anyway because of Java 1.6 dropping 32-bit support on MacOS. -We have several parts of the build that come very close to filling a 32-bit address space (and some advanced internal builds at Google go over the limit). -Compiling gcc as 64-bit measurably speeds up the build.
JBQ
In the same site, someone said he has uploaded the 32 bit version of toolchain anyway, here :
ls: cannot access device/*/m7pro/cm.mk: No such file or directory
build/core/product_config.mk:233: *** Can not locate config makefile for product "cm_m7pro". Stop.
Device m7pro not found. Attempting to retrieve device repository from CyanogenMod Github (http://github.com/CyanogenMod).
Repository for m7pro not found in the CyanogenMod Github repository list. If this is in error, you may need to manually add it to your local_manifests/roomservice.xml.
** Don't have a product spec for: 'cm_m7pro'
** Do you have the right repo manifest?
No such item in brunch menu. Try 'breakfast'
WTF !?
maybe this famous breakfast should have beeing run first, but how... ?
did you set up .repo/local_manifests/m7pro.xml? (see README on my github)
thanks for testing bt and gps. could you run a adb logcat|grep -i gps while you run a gps app?
(post it to pastebin and link it here)
gps/radio: right, gps+bt have a higher prio. But if i modify the Bluetooth.apk code anyway i will propably include the radio stuff.
Its interesting to see that the FM code is there, i am curious to see if it will actually work 8)
Sorry, I can't get adb working, my device is see as iddle or something like that (don't remember)
