HPH RK3288 ROM v1.2 by mo123 (20141117)
Has anyone else had issues with adjusting the contrast, brightness, and satcon?
I'm running v1.3 on my UBOX R89, and the problem is, sometimes when I make adjustments to the three listed above the satcon goes all the way up by itself. Then if I try to change it, it goes right back to max again.
If I do the reset, then it goes back to normal, but if I do too much adjusting then satcon goes back to max. I've been able to work around it mostly, but it is an annoyance.
Only other issue is the light during suspend, but that one I can live with
Thanks and cheers!
-SB---------------------------------------
Currently using U-BOX R89 with mo123 v1.6.
Other android tv device - ADT-1 running latest PureNexus 6.0.1 MM and very impressed with the changes vs stock molly!
Pipo M9S -- CrewRKTab custom rooted 4.4.2
RCA Viking Pro 10 -- Custom stock rooted 5.1 by me <- FOR SALE
----------- ROM by me, the first way to update ZTE Force 4G from ICS to JB http://androidforums.com/threads/fin...om-ics.886408/
Originally posted by theeze View PostGood work! All that's left is a working power button as power off reboots my R28 instead of turning off. I really like Mo's rom but the inability to turn off the machine was the deal breaker.
[QUOT=mo123;28ROM roblem.
Use 7zip program to unzip filI.
http://www.7-zip.org/download.html[/QUOTE]
I use 7z but the same result. Do we have any other link that i can use perhaps?
I will use the rom in a Beelink that I already use 1.2 !
I downloaded 1.2 today and no problem with unzipping that for i write you about the link.
Thanks god no more hiccups!!!
I hope 1.4 will be better !!!
You are great man !!!
That i wanted to say is that perhaps the file itself has a problem and not the link !Last edited by koutsouk; 23 February 2015, 21:40.
Originally posted by koutsouk View PostI am trying to download the 1.4 version but every time i try to unzip the file it seems to be broken.
I tried with firefox,chrome but the same results.
Is there a problem with the mediafire link maybe??
Can you please check it out ?
I've seen things that were downloading at like 60KB/s with Firefox's built-in download jump up to like 1.5-2MB/s (that's bytes not bits, which is about my max DL speed, which 15Mb. Little b means bits).
Then, too if the server drops the connection halfway through a 4GB download, you can pause and then resume and it will start where it got dropped. With regular Firefox download you'd have to start the download over.
Been using it for years. One reason why I prefer Firefox over chrome. There is not really an equivalent plugin for IE or chrome.
Cheers,
Pretty sure it's open source, too.
Most download accelerators/managers have either ads, malware, or most likely both. Especially for IE.
Not downthemall.
Cheers,
Not downthemall.
Cheers,
-SB
There are currently 2131 users online. 1 members and 2130 guests.
