HPH RK3288 ROM v1.2 by mo123 (20141117)
Originally posted by Steveboroughs View PostOdd, Ugoos is telling me different, that because of the "HDMI Switch" used it limits the output to 4K@30Hz, HPH_Tina said the same thing in a thread i read here about there box with the same PCB
Only way to know for sure.
I know new firmware added 4K 60Hz support which wasn't present in earlier firmware.
Hotspot bug
Originally posted by sawbones999 View PostMaybe the Wi-Fi chipset is overheating? You could try using a small piece of thermal tape (they come in little squares or in a big sheet that can be cut to fit) or thermal paste and either a small heatsink or a copper shim. I had this problem with a linksys wrt160n, and ordered the thermal pads bc I saw some others fixed theirs with thermal pad(tape) and copper shims but never got around to fixing it. I was just restarting it every few days when it overheated. I ended up replacing it recently with a linksys e1500 that I got for free from a client when I replaced the e1500 with something more heavy duty. I put dd-wrt on the e1500 and haven't had to restart it a single time since. It's extremely stable and been running now for weeks. I'm not using dd-wrt to increase the signal output above norma because I already get good reception at stock output throughout the house.
Check out this http://toomanycomputers.blogspot.com...ution.html?m=1
You can get the thermal pads and copper shims very cheap on **** if you don't mind waiting on shipping from China (could be a couple of weeks up to a month or possibly more depends where you live). If you order domestically you can expect faster shipping but cost will probably be a little bit more.
Could also be a software issue, but possibly worth trying this. I don't know which system you are using, but if you crack it open, I'd check under the heatsink of the cpu as well and if it has a thermal pad it's probably a good idea to replace it with thermal paste because the paste will transfer heat to the heatsink much better than the pa. It's very cheap and readily available on **** and lots of other places, too. Even local computer/electronics store should have it(though **** is likely cheapest. I use this a lot so I usually order about 6 syringes of it at a time. I don't see much difference in cooling if I check temps between the cheap stuff and more expensive brand names like arctic silver). Thermal paste conducts heat much better than the pads, but is probably fine for Wi-Fi chipset. Especially since it's sticky and you need to stick something to it to dissipate heat(thermal paste is not sticky). There is a thermal epoxy which is permanent. I have not tried the epoxy, though, so I can't say how well it works. Hope this helps!
Cheers,
-SB
Originally posted by gogo789 View PostThank a lot for your reply, I check the heat, but it's very not cold, i'm not sure that the Wi-Fi chipset is overheating. Is there a file where the system errors are logged, to check the cause of the reboot ?
Hotspot bug
Originally posted by mo123 View PostCan use Catlog app from the Play Store to log all actions/services operating on your device.
12-19 22:17:04.976 D/AndroidRuntime( 2734): Shutting down VM
12-19 22:17:04.986 D/dalvikvm( 2734): GC_CONCURRENT freed 97K, 15% free 600K/700K, paused 0ms+0ms, total 1ms
12-19 22:17:05.036 D/dalvikvm( 1125): GC_CONCURRENT freed 1358K, 39% free 6013K/9748K, paused 2ms+6ms, total 33ms
12-19 22:17:05.036 D/dalvikvm( 1125): WAIT_FOR_CONCURRENT_GC blocked 22ms
12-19 22:17:05.166 D/dalvikvm( 1125): GC_CONCURRENT freed 1800K, 38% free 6051K/9748K, paused 1ms+6ms, total 34ms
12-19 22:17:05.166 D/dalvikvm( 1125): WAIT_FOR_CONCURRENT_GC blocked 25ms
12-19 22:17:05.376 D/dalvikvm( 1125): GC_CONCURRENT freed 1501K, 36% free 6294K/9748K, paused 1ms+5ms, total 35ms
12-19 22:17:07.056 I/AudioTrack( 494): set() streamType 1 frameCount 0 flags 0004 channelMask 3 sampleRate 48000 format 1
12-19 22:17:07.116 I/AudioTrack( 494): set() streamType 1 frameCount 0 flags 0004 channelMask 3 sampleRate 48000 format 1
12-19 22:17:07.126 D/mali_winsys( 1125): new_window_surface returns 0x3000
12-19 22:17:09.056 I/AudioTrack( 494): set() streamType 1 frameCount 0 flags 0004 channelMask 3 sampleRate 48000 format 1
12-19 22:17:09.376 D/AndroidRuntime( 2759):
12-19 22:17:09.376 D/AndroidRuntime( 2759): >>>>>> AndroidRuntime START com.android.internal.os.RuntimeInit <<<<<<
12-19 22:17:09.376 D/AndroidRuntime( 2759): CheckJNI is OFF
12-19 22:17:09.376 I/AndroidRuntime( 2759): JNI options: '-Xjniopts:warnonly'
12-19 22:17:09.386 D/dalvikvm( 2759): Trying to load lib libjavacore.so 0x0
12-19 22:17:09.396 D/dalvikvm( 2759): Added shared lib libjavacore.so 0x0
12-19 22:17:09.396 D/dalvikvm( 2759): Trying to load lib libnativehelper.so 0x0
12-19 22:17:09.396 D/dalvikvm( 2759): Added shared lib libnativehelper.so 0x0
12-19 22:17:09.396 D/dalvikvm( 2759): No JNI_OnLoad found in libnativehelper.so 0x0, skipping init
12-19 22:17:09.396 D/dalvikvm( 2759): Trying to load lib librkbm.so 0x0
12-19 22:17:09.396 D/dalvikvm( 2759): Added shared lib librkbm.so 0x0
12-19 22:17:09.426 D/dalvikvm( 2759): Note: class Landroid/app/ActivityManagerNative; has 179 unimplemented (abstract) methods
Do you see what goes wrong ?
I also get the "device_info.txt"
build.board: manta
build.bootloader: unknown
build.brand: google
build.cpu_abi: armeabi-v7a
build.cpu_abi2: armeabi
build.device: manta
build.display: rk3288-eng 4.4.2 KOT49H Finless.1.2 test-keys
build.fingerprint: rockchip/rk3288/rk3288:4.4.2/KOT49H/eng.sz.20141016.091133:eng/test-keys
build.hardware: rk30board
build.host: finless_desktop
build.id: KOT49H
build.manufacturer: samsung
build.model: Nexus 10
build.product: mantaray
build.radio: unknown
build.serial: GDX1ZAGEPG
build.tags: test-keys
build.time: 1413421952000
build.type: eng
build.user: finless
version.codename: REL
version.incremental: eng.sz.20141016.091133
version.release: 4.4.2
version.sdk_int: 19
Originally posted by solomon_13 View PostHello I flashed the HPH_RK3288_ROM_v1.2_mo123 to a RKM 902II. It boots fine and I see apps but when it starts up it say to click to enable wifi. However not networks show up. Is there something else I need to do. This is my first attempt...noob.
Use the second tab of the flash tool to unpack your kernel & resource.img from your stock ROM.
If wifi is not working you might need to flash your boot.img also.
Originally posted by mo123 View PostYou need to flash your stock kernel.img & resource.img with this ROM since Rikomagic RKM 902II uses a different wifi chipset and configuration.
Originally posted by solomon_13 View PostOk, thank you so much for answering my question. I will do as you suggest tomorrow kids are watching tv now. I really like your rom. Is way cooler than the RKM stock. One more thing is there a way to get the exact same backgrounds you show in the tutorial. They look very nice with apps. Thanks again.
Guest
Originally posted by delldell View PostI just want to know that the wireless remote Rii Mini 25A, it provide a voice in fuction, can i use this fuction for this box? for example : can i just talk to my remote to search in Youtube.
Originally posted by Burs View PostI'm also wondering about that. I see both speaker and microphone, but I couldn't test it with any app. But generaly, it's a good remote. Maybe IR signal could be a little bit stronger, but hey, for $25 it's good enough for me (considering all other crappy remotes I tried).
p.s. I'll post again if i can use it for voice input.
THX
Originally posted by delldell View PostHi everyone,
I'm new in here, I plan to buy a HPH NT-V6.
Thx
Cheers,
-SB---------------------------------------
Currently using U-BOX R89 with mo123 v1.6.
Other android tv device - ADT-1 running latest PureNexus 6.0.1 MM and very impressed with the changes vs stock molly!
Pipo M9S -- CrewRKTab custom rooted 4.4.2
RCA Viking Pro 10 -- Custom stock rooted 5.1 by me <- FOR SALE
----------- ROM by me, the first way to update ZTE Force 4G from ICS to JB http://androidforums.com/threads/fin...om-ics.886408/
I received a Christmas gift from Google via FedEx yesterday, the ADT-1 developer kit which I applied for a couple months ago!
When I first plugged it in it updated to the latest OTA android L. First thing about it, I hate that the launcher will only allow apps to appear which have the required android tv intent. I found one other launcher in the online play store which shows regular apps (I think it's called smart launcher), but it looks like crap and the transition animations don't work right. The other thing I hate is no browser! I installed a couple of browsers but since the gamepad won't support mouse emulation natively (or touch emulation), I had to connect a mouse to be able to click anything in the browser. Next thing I hate is the included play store with only like 30 apps. I installed aptoide to circumvent this.
The BEST thing about it so far, it has Netflix DRM and in the 10min downscaling test ramped up to 5800kbps 1080p in less than 30 seconds. It's a shame we can't get that on these wonderful rk3288 devices. Antutu score around 37.5K, lower than the R28 Meta I have here.
The other bummer about adt-1 is a total lack of custom ROMs and kernels. Still looking forward to the R89 that I already know my dad got me for Christmas and mo123's 1.3 ROM!!
Cheers,
There are currently 2207 users online. 1 members and 2206 guests.
