HPH RK3288 ROM v1.2 by mo123 (20141117)
Originally posted by digitalriver View Post
Originally posted by mo123Can you post a link to latest UBox or Beelink firmware that work with your remote?
If you use the kernel.img & resource.img from UBox with the ROM, remote should work.
Might also need remote's *.kl file in /system/usr/keylayout folder for all the buttons to work.
The power button of the remote is mapped inside the kernel of Ubox.I using kernel from here: http://www.freaktab.com/showthread.p...l=1#post247938
Change this in /system/build.prop file
ro.product.device=hammerhead to ro.product.device=rk3288
Need to be rooted and enable RW permission on system in ES File Manager.
If frequency switcher still doesn't work, then changing more things can make it work but then Youtube 1080p will not work. Please test if only above change still make Youtube 1080p work.
Originally posted by mo123Yes, you will loose all the improvements in the kernel from the last two months.
Can try to use kernel from this newer UBox firmware of 19/12/14
http://www.mediafire.com/download/68...k4110_1219.img
I am running the 1.4 Rom on Beelink R89. Works great with the already known problems (power off not working, power led not changing, cannot change to physical keyboard).
But I found an issue with the ethernet MAC address. It is changing at every reboot. I need a static MAC to be able to implement QoS rules for the box. Is there any reason why this is changing at reboot?
Guest
Originally posted by hueb_s View PostBut I found an issue with the ethernet MAC address. It is changing at every reboot. I need a static MAC to be able to implement QoS rules for the box. Is there any reason why this is changing at reboot?
One other problem I've been thinkering about for awhile, is not been able to start FTP server inside Solid Explorer. Anyone using it, so it can be confirmed? Whether I use LAN or WLAN connection, the error message says "failed to bind to address 0.0.0.0". Fake Wifi Connection xposed module doesn't help either, although it helps configuring the server for SSID I'm connected to (otherwise I get unknown ssid and "none" for server address, which should be something like 192.168.x.x).
Rom works ok on Ugoos UT3 4gb 32gb with fan, except fan never runs.Last edited by Electroman; 09 January 2015, 14:10.
Guest
Originally posted by mo123Strange that Tronsmart is not providing support or new firmware anymore.
They were the first to release RK3288 devices.
Speaking of which, is there any RK3288 vs AW80 tests that have some credibility (not just Antutu scores)?
Many times I asked myself should I have waited a bit more and purchased one of AllWinner devices...
Originally posted by mo123Yes, just replace with your resource.img from stock tronsmart ROM.
I tried that kernel with this rom and no go.
Cheers,
-SB---------------------------------------
Currently using U-BOX R89 with mo123 v1.6.
Other android tv device - ADT-1 running latest PureNexus 6.0.1 MM and very impressed with the changes vs stock molly!
Pipo M9S -- CrewRKTab custom rooted 4.4.2
RCA Viking Pro 10 -- Custom stock rooted 5.1 by me <- FOR SALE
----------- ROM by me, the first way to update ZTE Force 4G from ICS to JB http://androidforums.com/threads/fin...om-ics.886408/
Originally posted by sawbones999 View PostI have tried this and it is not working. I also tried using stock boot.img. I was only able to get tronsmart working with stock resource.img and the last kernel you made and posted for v1.2.
Cheers,
-SB
any suggestions?
thanks
Originally posted by mo123Can't use a different boot.img as it will not work.
You have to use the included kernel or one after 26/12/14 from Tronsmart(that doesn't exist at the moment).
Only solution is to keep asking Tronsmart for new firmware.
Do you or anyone else in the thread know how to enable bluetooth at boot? Most other fw does this automatically, but not yours. This is not SO big a deal now that IR is working and BT can be enabled that way, but it's really annoying when you have to connect a mouse (bc no IR) every time you restart, just so you can connect bt keyboard/touchpad.
Thanks!
There are currently 2084 users online. 2 members and 2082 guests.
