HPH RK3288 ROM v1.2 by mo123 (20141117)
    I think I have it narrowed down to the init.rc (BT not being initialized on boot), but I can only mount the system.img on windows with DiskInternals Linux Reader. The build.prop is nearly identical so I don't think that the problem is in there.
    Which image file is init.rc stored in, and how can I access it?
    I may try to modify my init.rc on the r28 and see if I can get it working. I'm seeing different ways to do that in various sample init.rc's from google search.
    Thanks!
    -SB
    Currently using U-BOX R89 with mo123 v1.6.
    Other android tv device - ADT-1 running latest PureNexus 6.0.1 MM and very impressed with the changes vs stock molly!
    Pipo M9S -- CrewRKTab custom rooted 4.4.2
    RCA Viking Pro 10 -- Custom stock rooted 5.1 by me <- FOR SALE
    ----------- ROM by me, the first way to update ZTE Force 4G from ICS to JB http://androidforums.com/threads/fin...om-ics.886408/
      Boot.img
      Android Image Kitchen http://forum.xda-developers.com/show....php?t=2073775
      RK3288 Devices
      - Overview BOX (LINK !)
        Originally posted by no_spam_for_me View Post
        I have dixda's android kitchen on my laptop. It never really occurred to me that it might be compatible.
        I downloaded a rockchip kitchen from the forum here onto my server and then I realized I don't have cygwin installed on it. Just on my laptop, so I'm running a full cygwin install.
        I think I made the necessary modifications but it would be nice to compare it to something. If the problem is with init.rc and that resides in boot.img, it doesn't make sense that it wouldn't be the same as original tronsmart ROM because I'm using tronsmart resource and boot image.
        Oh well. Gotta go to a dinner thing at my wife's friend's house. I'm never going to complete these couple projects that I have going for other people...
        Cheers,
        -SB
          how play bluray 3d iso (3d mode)?
            i try open iso files with built in video players (two) nothing happening.
            only "loading video"
              if it possible:
              change way to open app in Launcher - if dir include only one app, directly open, if not - open window for choice, if want add new app to directory use long press
              switch ON location service (default) else doesnt work weather
              included file commander can't mount samba dirs, but ES File Explorer work perfect
              add Power off button on Launcher
              root?
              full 3D support
                after click ShutDown button on bottom, occur restart
                  yes, i've ubox 8gb
                    latest kernel for r89
                    Originally posted by mo123
                    Then you can unpack firmware with flash tool(second tab) and flash kernel.img and resource.img with my ROM's or just use latest stock firmware here
                    http://www.mediafire.com/download/68...k4110_1219.img
                    hi
                    I've downloaded this link and unpacked it but there is no kernel in.
                    would you please upload latest kernel for r89?
                    thanks.
                      Then Beelink puts the kernel inside the boot.img.
                      Will try to modify the boot.img with kernel so it works on your device.
                      Can you upload the boot.img only, since I don't want to download a complete ROM for only boot.img?
                      hi and thanks for your reply.
                      I will upload boot.img of latest firmware's r89 and make link it.
                        latest boot.img r89
                        excuse me for I was late.the link of latest boot.img for r89 is
                          Hi mo123.. Was it possible to make a boot.img for the rikomagic i posted for you some time ago?? The rikomagic mk902ii.. Regards
                          Sent from my iPad using Tapatalk
                            Can you reupload the boot.img to a different host?
                            The previous download link is filehopper, boot.dol and doesn't seem to work.
                            Link to my Dropbox
                            https://dl.dropboxusercontent.com/u/16513602/Image.rar (20mb)
                            It include everything except the system.img. Let me know if you need any files and i will provide it.
                              You can use this kernel I made for Beelink R89.
                              Use it with my HPH RK3288 ROM v1.2/v1.3(remember to use separate updated boot.img)/v1.4 and v1.5(to be released).
                              PS: Remember to use your stock resource.img from the unpacked Beelink/Ubox R89 mediafire link I posted above for remote to work correctly.
                              Yes man, this is great. I don't need anymore to tamper with resource.img from yours ROM to install yours kernel on R89. Especially if I do not completely understand why in "flat device tree blob" (dtb) there are three GPIOs associated with ACT8846 driver (GPIO7? A1 Active Low as VSEL, GPIO0 A2 Active Low as SLEEP??, GPIO0 A2 Active Low as POWER_HOLD?) when FireFly (GPIO7 B6 Active Low as VSEL and GPIO0 A1 Active High as PWR_HOLD) and Beelink R89 declare only two (GPIO7? A1 Active Low as VSEL and GPIO0 A6 Active High as PWR_HOLD).
                              I will try to install your ROM v1.4 in my Beelink R89 on next day or v1.5 if it will be completed until then .
                              RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
                                sugestions for next ROM
                                please include mceusb driver and mce ir remote files.
                                See this thread http://www.freaktab.com/showthread.p...and-MCE-remote
