[Pipo-Project] M7Pro kernel
    Originally posted by d33 View Post
    I'll fix the camera & the compass - what about battery consumption though?
    Hi D33,
    I will let you know as I am testing that now.
      I'm still testing, have no conclusion at the moment
        test..
          Hi D33,
          I have tested the power consumption (display on and set to 25% brightness, Wifi on) and see very little difference between GPS on (Location set to device only), GPS off (Location set to battery saving), and with non-working state after soft reboot (Location set to device only). They all have a battery decrease of 1% approximately every 4-5 minutes. This give my tablet an operating time of just under 7 hours with full use. If the tablet goes into sleep mode the power consumption decreases to about 2-3% an hour. The major power consumption is caused by the display from the testing I have done.
            v15
            Notes:
            Switched GPIO for camera
            Changed gyro
            Donate to Finless
              v15
              Notes:
              Changed gyro
              Hi D33,
              The link to v15 doesn't work.
                Hello D33, just to let you know that my screen is once again reversed on V14.
                Is there something I can do myself when this happens ?
                Last edited by JohnThomson; 23 May 2015, 01:26. Reason: Version number incorrect, sorry
                  Originally posted by tgray View Post
                  Hi D33,
                  does now
                  Donate to Finless
                    No, just report it
                    @raxy
                    Have pushed all changes and labeled as v15
                    Donate to Finless
                      v15
                      Notes:
                      Changed gyro
                      Hi D33,
                      Compass is still 90 degrees out as before and the flash still doesn't work. Attached is the dmesg.
                        No, just report it
                        @raxy
                        thank you , this will really help matching binaries with their source codes.
                          Hello D33, now on 1.34.15 I have to press quite hard near the top of my screen to activate the
                          icons at the bottom. Left to right seems to be correct.
                          Kind regards, John
                            v16
                            Notes:
                            Corrected annoying Flash typos
                            Tried one last mux setting for flash
                            Amended AK9863 layout to 8 (was 5)
                            Donate to Finless
                              v16
                              Notes:
                              Hi D33,
                              Sorry to say camera flash and compass still do not work. The compass now just swings and rotates 360 degrees.
                                v17
                                Notes:
                                Camera code amended to 0-c7
                                Donate to Finless
