[Pipo-Project] M7Pro kernel
1.32.11 was using the M9Pro configMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Using the correct .config !Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Thanks TriA. I'm home now and have access to a Pipo M8HD for testing. I'll post when I have something that seems close.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Hi D33, I have been running tests on 1.32.07 all today as this works the best on my tablet. It looks like the DVFS may be the problem but I am not sure. When I have BT working the DMESG shows DVFS MSG: AVS Value(index=0): 178 179 180 179 179 179 180 178 180 178 and when the BT doesn't work the DMESG shows DVFS MSG: AVS Value(index=0): 1 1 1 1 1 1 1 1 1. I have tested this may times today and it is always the same. I have attached the dmesg files for when no BT was working and when BT was working. There is still the problem of no internet using BT but the file transfers work when BT is running.Attached Files
tgray try this then?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
tgray - I've built this one without ct36x supportMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Hi d33, Screen is rotated 90 degrees to the right. Battery display doesn't work. BT is still touch and go (seems to work okay when you power off and then restart but does not work when you just reboot the tablet tried about 4 times each and the same everytime). Brightness control is reversed. GPS works okay. Tablet runs slower but not too bad.Attached Files
Originally posted by d33 View Post
screen wrongly rotated (-90°)
slider for baclight brightness effect is reversed , and in mid to rightmost slider range : nothing changes
BT seem ok (can detect other phones), but yes, after 1st reboot, works no more (cannot be turned on)
GPS , not fully tested
battery level always 0% (wrong)
Originally posted by raxy View Post
In this one, touch screen is ok,
battery level always 0% (wrong)Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
1.32.15Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
1.32.15 test report :
screen still wrongly rotated (-90°)
slider for baclight brightness effect still is reversed , and in mid to rightmost slider range : nothing changes
BT seem ok (can detect other phones), but yes, after 1st reboot, still doesnt work (cannot be turned on, see error msg in dmesg)
There are currently 2499 users online. 1 members and 2498 guests.
