[Pipo-Project] M7Pro kernel
Donate to Finless
Originally posted by tgray View PostMy HDMI works the first time after the new install with the .17b kernel but if I shutdown and restart it stops working. Also I just found that the USB OTG does not work.
What is not working with OTG? Everything or just some devices? Is it a power issue?
Donate to Finless
The OTG port appears to be initialising ok in "Both Device & Host" mode. I can provide variants for that do host only or device only as a test.
Code:<6>[ 2.888004] DWC_OTG: ^^^^^^^^^^^^^^^^^Device Mode <6>[ 2.888044] usb20_otg usb20_otg: DWC OTG Controller <6>[ 2.888141] usb20_otg usb20_otg: new USB bus registered, assigned bus number 1 <6>[ 2.888200] usb20_otg usb20_otg: irq 48, io mem 0x00000000 <6>[ 2.888233] DWC_OTG: dwc_otg_hcd_start controller in device mode,everest <6>[ 2.888301] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 <6>[ 2.888341] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 <6>[ 2.888384] usb usb1: Product: DWC OTG Controller <6>[ 2.888412] usb usb1: Manufacturer: Linux 3.0.36+ dwc_otg_hcd <6>[ 2.888444] usb usb1: SerialNumber: usb20_otg <6>[ 2.888735] hub 1-0:1.0: USB hub found <6>[ 2.888765] hub 1-0:1.0: 1 port detected <6>[ 2.893615] DWC_OTG: host20_driver_probe host2.0 reg addr: 0x101c0000 remap:0xdf200000 <6>[ 3.104046] DWC_OTG: ^^^^^^^^^^^^^^^^^^Host Mode <6>[ 3.104073] usb20_host usb20_host: DWC OTG Controller <6>[ 3.104115] usb20_host usb20_host: new USB bus registered, assigned bus number 2 <6>[ 3.104154] usb20_host usb20_host: irq 49, io mem 0x00000000 <6>[ 3.104203] DWC_OTG: Init: Port Power? op_state=1 <6>[ 3.104216] DWC_OTG: Init: Power Port (0)
Code:<4>[ 3.253877] func rk_hdmi_power_init, line 1259: <4>[ 3.536339] CAT66121: Reg[0-3] = 0x[54].[49].[12].[16] <4>[ 3.536377] [CAT66121] Device found! <6>[ 3.635731] cat66121_hdmi 2-004c: cat66121 hdmi i2c probe ok
Code:<6>[ 11.133738] DWC_OTG: dwc_otg_hcd_enable, disable host controller <6>[ 287.943610] DWC_OTG: ********vbus detect********************************************* <6>[ 288.128808] DWC_OTG: ********soft connect!!!***************************************** <6>[ 288.134817] DWC_OTG: USB SUSPEND <6>[ 288.268332] DWC_OTG: USB RESET <6>[ 288.455743] android_work: sent uevent USB_STATE=CONNECTED <6>[ 288.459118] DWC_OTG: USB RESET <6>[ 288.711568] android_usb gadget: high speed config #1: android <6>[ 288.711801] android_work: sent uevent USB_STATE=CONFIGURED <4>[ 290.486882] DWC_OTG: req 80.06 v0303 i0000 l0200 protocol STALL; err -22 <4>[ 290.598756] DWC_OTG: req 80.06 v0304 i0000 l0200 protocol STALL; err -22 <4>[ 290.669109] DWC_OTG: req 80.06 v0303 i0000 l0200 protocol STALL; err -22 <4>[ 290.775030] DWC_OTG: req 80.06 v0304 i0000 l0200 protocol STALL; err -22
Last edited by d33; 17 May 2015, 09:16.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Logcat on HDMI:
Code:05-17 08:38:32.749 D/HdmiControllerActivity( 985): onPreferenceThreeClick() ==>> isConnected=false 05-17 08:38:32.749 D/HdmiControllerActivity( 985): setHdmiConfig 05-17 08:38:32.749 D/AudioHardware( 131): AudioHardware pcm playback is exiting standby. 05-17 08:38:32.749 D/AudioHardware( 131): openPcmOut_l() mPcmOpenCnt: 0 05-17 08:38:32.749 D/alsa_route( 131): route_info->sound_card 0, route_info->devices 0 05-17 08:38:32.749 D/alsa_pcm( 131): pcm_open(0x0001f000) 05-17 08:38:32.749 D/alsa_pcm( 131): pcm_open() card 0, device 0, Playback 05-17 08:38:32.749 D/alsa_route( 131): route_set_controls() set route 0 05-17 08:38:33.549 D/HdmiControllerActivity( 985): onPreferenceThreeClick() ==>> isConnected=false 05-17 08:38:33.549 D/HdmiControllerActivity( 985): setHdmiConfig 05-17 08:38:34.619 D/HdmiControllerActivity( 985): onPreferenceThreeClick() ==>> isConnected=false 05-17 08:38:36.449 D/HdmiControllerActivity( 985): onPreferenceThreeClick() ==>> isConnected=false 05-17 08:38:37.849 D/HdmiControllerActivity( 985): setHdmiOutputStyle 05-17 08:38:37.849 D/HdmiControllerActivity( 985): strbuf=1920x1080p-60 05-17 08:38:41.849 D/AudioHardware( 131): AudioHardware pcm playback is going to standby. 05-17 08:38:41.849 D/AudioHardware( 131): closePcmOut_l() mPcmOpenCnt: 1 05-17 08:38:41.849 D/alsa_route( 131): route_set_controls() set route 24 05-17 08:38:41.849 D/alsa_pcm( 131): pcm_close() card 0, device 0, Playback
Donate to Finless
Hi D33,
I have just tested the .17b kernel on a second M7 Pro and it does exactly the same thing as mine (bought by a friend about 3 month after I got mine). The HDMI & OTG work after flashing and if you just reboot they continue to work but as soon as you power off and then restart the tablets the HDMI and OTG no longer work. I check the OTG and it is not a power issue. Everything else works okay as far as I can tell (WIFI, Camera, GPS, Bluetooth file transfer & internet, etc).
Removed VTL CT363 support for now
USB OTG set to Host/Slave but now defaults to HOST (was USB_ID dependant)
Download
NotesMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Donate to Finless
Originally posted by raxy View Posttgray
maybe you should redo a complete nand flash of all partitions (from RROM 3.4.2) and not only the kernel's one so that no interference from previous ROM can occur.
If this confirms that all features are working, .17b would become a big milestone in freaktab's history !
I always do a complete nand flash of all the partitions when trying these kernels.
D33, I will try the new kernels tonight and let you know if there is any improvement.
I've tested the 1.33.02 kernel under 3 conditions:
- just after flashing the kernel;
- after power cycle;
- after reboot
Touch screen, brightness control, rotation sensor, Wi-Fi and HDMI are OK in all 3 cases.
BT isn't working just after flashing the kernel, but is OK after power cycle, and isn't working again after reboot.
GPS behavior is the same as BT (with screen off; it isn't working at all when screen is on).
OTG was OK (USB mouse for example) only after flashing the kernel, but isn't working (no power on OTG) after power cycle and/or reboot.
Originally posted by TriA View PostI've tested the 1.33.02 kernel under 3 conditions:
- after reboot
... and what about 1.33.01?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
There are currently 3006 users online. 0 members and 3006 guests.
