[Pipo-Project] M7Pro kernel
    I just flashed 1.32.09 and wifi works on my tablet. Is there anything else I need to check?
    Randy
      I just checked GPS...it isn't working.
      Randy
        I compared the GPIO output between 1.32.07 kernel and stock kernel
        there is a lot of differences
          Originally posted by TriA View Post
          maybe, some production batches of m7pro use different chip?
          DMESG says:
          GPIO error with MIPI chipset:
          <4>[ 0.515654] ssd2828_gpio_init: request ssd2828_spi->miso_PIN error
          <4>[ 0.898946] autorequest GPIO-191
          <4>[ 0.898995] [<c0674470>] (unwind_backtrace+0x0/0xf4) from [<c06a7f48>] (warn_slowpath_common+0x54/0x64)
          <4>[ 0.899068] [<c06a7f48>] (warn_slowpath_common+0x54/0x64) from [<c06a7f88>] (warn_slowpath_fmt+0x30/0x40)
          <4>[ 0.899140] [<c06a7f88>] (warn_slowpath_fmt+0x30/0x40) from [<c0934454>] (gpio_ensure_requested+0x54/0x1b0)
          <4>[ 0.899217] [<c0934454>] (gpio_ensure_requested+0x54/0x1b0) from [<c09347ec>] (gpio_direction_output+0xa0/0x23c)
          <4>[ 0.899299] [<c09347ec>] (gpio_direction_output+0xa0/0x23c) from [<c0946128>] (ssd2828_power_up+0x58/0x80)
          Bluetooth initialised ok on AP6476:
          <6>[ 14.718549] [BT_RFKILL]: Enter rfkill_rk_init
          <6>[ 14.718690] [BT_RFKILL]: Request irq for bt wakeup host
          <6>[ 14.718780] [BT_RFKILL]: ** disable irq
          <6>[ 14.748832] [BT_RFKILL]: bt shut off power
          <6>[ 14.748863] [BT_RFKILL]: ap6476 device registered.
          Goodix TS GPIO error on suspend:
          <4>[ 167.462572] autorequest GPIO-207
          <4>[ 167.462827] [<c0934454>] (gpio_ensure_requested+0x54/0x1b0) from [<c09347ec>] (gpio_direction_output+0xa0/0x23c)
          <4>[ 167.462911] [<c09347ec>] (gpio_direction_output+0xa0/0x23c) from [<c0a593e0>] (goodix_ts_early_suspend+0x44/0xbc)
          <4>[ 167.463013] [<c0a593e0>] (goodix_ts_early_suspend+0x44/0xbc) from [<c06e3a64>] (early_suspend+0xe0/0x158)
          Wifi Sys Interface loaded:
          <4>[ 2.779961] Rockchip WiFi SYS interface (V1.00) ...
          SDIO card detect start:
          <6>[ 14.738839] rk29_sdmmc_change_clk_div..1702.. newDiv=40, newCLK=300Khz [sdio]
          but no wifi card detected? However, it did pick up your wifi card in 1.32.05
          From 1.32.05 DMESG:
          <4>[ 112.581058] wifi_driver_write: enable = 1
          <4>[ 112.581092] ================================================== =====
          <4>[ 112.581126] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
          <4>[ 112.581155] ================================================== =====
          <4>[ 112.581182] WiFi driver (Powered by Rockchip,Ver 4.74.WFD.OOB) init.
          <6>[ 112.581213] dhd_module_init: (D33) Enter
          <4>[ 112.581730] =========== WLAN placed in POWER ON ========
          <6>[ 112.581898] wifi_set_power = 1
          <6>[ 112.581917] rk29sdk_wifi_power: 1
          <6>[ 112.840422] wifi turn on power
          <6>[ 113.284865] mmc_attach_sdio..1112.. ===== Begin to identify card as SDIO-card. [mmc1]
          <6>[ 113.328493] rk29_sdmmc_change_clk_div..1702.. newDiv=0, newCLK=24000Khz [sdio]
          <6>[ 113.335060] mmc1: new high speed SDIO card at address 0001
          <6>[ 113.337031] sdmmc_rescan_try_freq..1867.. ===== Initialize SDIO successfully. [mmc1]
          <4>[ 113.337229] bcmsdh_register: Linux Kernel SDIO/MMC Driver
          <4>[ 113.338469] FW_PATH = /system/etc/firmware/fw_RK901.bin
          <4>[ 113.338490] NVRAM_PATH = /system/etc/firmware/nvram_AP6476.txt
          <4>[ 113.339117] dhd_conf_set_hw_oob_intr: Enable HW OOB for 43362
          Version 1.32.10 built to address these issues (hopefully)!
          Donate to Finless
            Hi d33, The touchscreen does not work on 1.32.10 so I cannot test any further.
              tgray could you produce a dmesg for me via adb?
              Donate to Finless
                Without DMESG I'm guessing but ...
                Donate to Finless
                  Hi d33, I have only just got adb working on my comp so I will do some dmesg for you tomorrow as I am off to bed. I will also try 1.32.11 and let you know if there is any problems. I did find that on 1.32.07 the BT worked to start with but then started to play up (not starting, not finding other BT devices that I have used before) but the GPS still works okay.
                    you both have lost me...I hope randy is still catching up
                      Flash the test kernels and post a DMESG
                      Donate to Finless
                          Here's my dmesg file with 1.32.11:
                          Screen rotation is off 90 degrees counterclockwise
                          Battery meter doesn't work. Shows 0% with a 100% charge
                          Touch Screen works
                          GPS is still disabled
                          Wifi and touch screen work fine.
                          I tried 1.32.10 but touch screen didn't work.
                          I'm off to work in the hospital all day/night....so I though I would at least try these two test kernels for you. Good luck!!!!!
                          Randy
                            No touchscreen and hell bunch of error messages in DMESG
                            1.32.11:
                            Touch OK
                            HDMI is OK
                            No Wi-Fi (it just doesn't allow to switch it on)
                            No battery status (0%)
                            No GPS
                            No BT (but I was able to delete previosly saved pairing with my phone, unlike all other 1.32.XX kernels)
                            Swapped axis (X <=> Y) of rotation sensor
                            Reversed brightness scale
                              dee,
                              regarding the pipo kernel tree in the m7p SDK,
                              I added a + to kernel_local_release in .config
                              but kernel.img still unbootable...
                              what did you do exactly to make it bootable ?
                              tks.
                                dee,
                                tks.
                                make -j2 nconfig
                                - General setup
                                --- Cross Compiler tool prefix -> arm-linux-gnieabihf-
                                --- Local version -> +
                                [save]
                                make -j2 kernel.img
                                Donate to Finless
